Fuel Door Dilemma (not the one you think)
So I pull up to get gas tonight (literally on "E") and press the button to release the fuel door. I heard a loud "snap" and the fuel door remained closed. Thinking this was some sort of fluke, I pressed the button multiple times to no avail. The door remains closed. Only a faint "click" can be heard now though. Much quieter than the normal release sound. I tugged on the manual release inside the trunk but it didn't seem to be doing anything. I tried pushing in as well as pulling out on the fuel door while pressing the release and also while pulling the manual release.
I pulled the trunk liner back and located the actuator. I can manually manipulate the release and it doesn't seem to be under any spring pressure like you would expect. If I manually slide the release into the open position it just stays there. If I slide it to the locked position and press the release button I get the normal "click" sound as the release opens, but only once. Any further pressing of the release button afterwards results in the much quieter "click" noise as the release does not return to the closed position. Also, while manually manipulating the release, I can hear noises inside the fuel door area. These facts lead me to believe that the release is broken somewhere inside the fuel door. At the very end of the cable. Perhaps the latch itself is broken.
All that being said, I'm not seeing any simple way to open the fuel door without taking the car apart or damaging the fuel door/paint. If anyone has a solution for this I would definitely like to know for future reference. I see lots of videos and forum posts about the "broken spring" fuel door issue, but no solutions for when the door is stuck CLOSED. Not OPEN. Thankfully I was at a local gas station in a good area. I'd hate to be on a road trip at some truck stop and have this happen. Just the thought of being stranded hundreds of miles from home simply because I can't open my fuel door is infuriating.
Also, all replacement parts I can find seem to be the entire actuator, cable and latch assembly. Being as the actuator seems fine, is there any way to buy just a replacement cable and latch?
Thanks in advance.
UPDATE: Got it open. Video at the bottom of thread.
Thanks in advance.
Sorry I can't help, but just wanted to make a comment about gas caps. My own opinion is that due to the Corvette's racing heritage, I think it would be fine if the Corvette had a nice big exposed gas filler cap that was tastefully integrated into the style of the car. No remote latch needed. Much like on the Shelby Cobra or something like on C2 Corvettes. Hopefully a method could be devised so that the filler cap is secure, while at the same time, it is easily serviceable if the security fails. The grief that RightSideUp is experiencing now is just is not worth it.
Received 3,343 Likes
2023 C6 of the Year Winner - Modified
Sounds almost like the mechanism itself broke internally but the solenoid is still engaging. I'm not entirely sure what the solution is but I believe your going to have to take it apart to get to the route of the problem. You may be able to access it through the wheel liner but dont quote me on that. Worth a look.
I was able to make it to a friends shop on what little fuel I had. We will be taking it apart there. The videos I've seen all show the wheel and wheel liner being removed and accessing it through there. So I believe you are correct.
Have you tried taping the painted edges and applying mild pressure to see if the door opens when you activate the opener? Not that it will solve your problem but I'm wondering about the nature of the failure and what others might do in the same situation.
Might be a dumb idea, but it crossed my mind while I had the trunk open. The whole point of the locking fuel door is security. Maybe partially style, but mostly security. What if there was a backup fuel filler inside the trunk? For these occasions, just so you won't get stranded. Definitely something with a non-venting cap (since the one outside does all the venting). Probably a huge safety hazard that manufacturers would rather not deal with. Just a thought.
Thanks for making that point, hopefully we can make this issue well known and easy to solve.
Received 1,789 Likes
Found this brute force solution on another Corvette forum:
“pryed it open..put piece tape so i can open it with plastic credit card“
They didn’t say if it damaged anything. I’m assuming they would have masked off all contact areas with something like duct tape and used a flat pry bar to spread the pressure over a wider area. I’d hate to be in the position where this was my only option.
After the events of last night, I can whole heartedly agree with you.
My 1960 Corvette just had a cover (similar to C6), but was not latched. Just lift the cover and remove the gas cap. My current Cadillac has a similar cover that you just push on from the outside and it opens to remove the filler tube. There is not even a gas cap on it the filler tube. I suppose a simple system like that on a Corvette would be too insecure due to jealous people that want to cause mischief.
Actually, the cap outside is sealed airtight. Venting is controlled through the EVAP system. Interesting idea about the emergency filler in the trunk, but probably hazardous because if the trunk gas cap were to start leaking, it would be a huge bomb waiting to happen. But, maybe that emergency filler could be somewhere else that is not so airtight.
The current design is probably the best considering the rarity of a situation like mine. All designs are destined to fail in some way. Would be nice to have one more fail-safe though!
The following 6 users liked this post by BigBlok502:
07BlackBlack (10-29-2022),
dr_gallup (10-30-2022),
FatsWaller (10-29-2022),
Mark333 (10-30-2022),
mbsigman (10-29-2022),
and 1 others liked this post.
Small update:
The dealerships seem to be the only ones who keep this part in stock aside from online parts stores. Here is the part name and number for anyone interested: Fuel Filler Door Lock Actuator - GM (25744292)
Can't seem to find the individual cable and plunger, only the entire actuator assembly. Kind of a bummer. I'd like to have an extra cable/plunger for a spare. It would be a cheap part that could easily be stored in the trunk. That way if I ever have this problem again it would be a simple matter of finding some tools to make the repair. Regardless of how far away from home I am.
The nearest dealer with one in stock is about 120 miles from me. $160 with tax. I have a friend who will be passing through that area this weekend. Should have the part in hand by the start of next week. Will post an update then.
Haven't had a chance to disassemble the car yet. Waiting to get the part in so I can put it all back together in the same day.
UPDATE:
Fuel door is open!!! After brainstorming all day I figured I'd give it one more try before resorting to taking the car apart. I know I still have to make the repair, but I'd rather do it at my place and not have my car stranded on someone else's property.
The effort paid off and I was able to open the fuel door, fill her up and bring her home. Also, to anyone else who may wind up in this situation, I'm making a video to show you how I did it.
So no, you don't have to be stranded hundreds of miles from home if this ever happens to you. And yes, you can get the fuel door open without damaging anything.
ClothSeats (10-29-2022)
The following 9 users liked this post by RightSideUp:
4SUMERZ (10-29-2022),
87SAM (10-29-2022),
BigBlok502 (10-29-2022),
FatChance (10-29-2022),
and 4 others liked this post.
