Care for your 'California Duster'
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
If you have ever used a 'California Duster', you know how well they work keeping your car free of dust. They are not intended to actually clean your car, but once your car has been washed and waxed, a California Duster [if used regularly] will keep the car nice much longer. That is if the car only gets dust on it.
I have found that it will streak windows because of the wax film on it, so I don't use it at all on the glass.
Anyway ... to my question:
This duster can get pretty dirty over time, so I feel the need to wash it well with soap and water sooner or later. Of course, when it finally does get washed good with soap, the wax on the fibers is gone.
Is there anything that can be applied that will give the duster back it's dust removing capabilities once it's finally cleaned real good?
Thank's in advance,
Ron
Thank's in advance,
Ron
I have been told not to wash it, just shake it out a bit before each use. The older it gets the better. Realistically with the low cost of a California Duster when it reaches the point that you are concerned with its condition I would just buy another one.
Location: Stafford VA, home of our wolf den. No house break ins to date.
wash it = ruined it.
just take a shotty micro fiber towel and rub it with that to take off the major dirt film.
all three of mine are over 5 years old.. no problems.
if you prepped it right, ie: place it on newspaper in direct sunlight for 48 hrs.. the wax film should not be streaking your windows...
Wounded Warrior Escort '11
I think I heard they've got a wax chemical inside of them that attracts the dust. They do "fill up" after many uses. My first one, I used for several years till it stopped sucking up the dust. Bought a new one and kept right on going. You cannot wash them as the chemical will wash out therefore no longer working as intended.
When done using mine, I put the handle between both hands, then move my hands back and forth (like you're trying to warm your hands up).
It spins it like crazy, and some of the larger particles fly out.
I learned that at the Prescott Car Show when I loaned mine to a fellow Vetter (he had a beautiful '57), that had forgotten to bring his. He showed me that trick.
Thank's for all the good info. I guess I just won't wash the duster.
Ready Mix concrete?
Ready Mix concrete?
Been using genuine California Car Dusters for many years and they work great if you lay them on newspaper for 24 hours before the first use. Just shake them out before and after each use and never ever wash it as it will be ruined. I use it on the glass every time and never have had any steaks.
My 2007 LMB convert has only been washed twice in 5 years but has never seen rain or even a puddle so doesn't get dirty, just dusty so only thing it needs is the duster to keep it looking new.
This picture was recently taken and the car had not been washed in over a year only used a duster:
For me I just use it if I can see dust on the car. I never use a car cover because I drive it sometimes 2 or 3 times a day nearly every day and average around 75-100 miles a week. I would say I use the duster around once or twice a week at the most to keep it dust free.
To the OP..
If your CA duster is leaving streaks on the glass, you've not used it enough yet. And BTW, it's probably leaving steaks on the paint somewhere too.
