Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-15-2011, 07:30 AM   #1
madcadr
CF Senior Member
madcadr's Avatar
Default Could a bad starter cause a dead cell in battery?
Could a bad starter cause a dead cell in the battery?
Dealership replaced battery first because I got the message "Service Charging System" - They told me that I had to pay for battery because GMPP does not cover it.
THEN, they tell me that the car still would not start and they have to replace the starter - So, I read under my GMPP that a non-covered part WILL be covered if caused by a failure of a COVERED part - Thus the question above.
If a bad starter can cause a dead cell in a battery (Battery only 14 months old) - Then, it SHOULD be covered under GMPP...
Thanks for any answers.
madcadr is offline   Reply With Quote
Old 12-15-2011, 08:07 AM   #2
Twisted1
CF Senior Member
Is say it could go both ways.
More likely the bad battery took out the starter.
When your battery has lower voltage(dead cell) it causes the items that use it to draw more amps. So most likely the battery took out the starter.
Id pay for the battery and be happy I got a free OEM starter.
Twisted1 is offline   Reply With Quote
Old 12-15-2011, 08:24 AM   #3
AORoads
CF Senior Member
AORoads's Avatar
I think he's having to pay for both, but I'd agree that usually when a batt. goes, it can take down a starter. It can also take down an alternator but in the case of the alternator, that's where it can go either way (alternator first). Let's see what others think on this matter tho...
AORoads is offline   Reply With Quote
Old 12-15-2011, 08:27 AM   #4
yeller z06
CF Senior Member
yeller z06's Avatar
I don't think a starter - or any other device - is going to cause a cell to go bad.
GM Delco batteries are not renowned as being the best in the world. And if you run it down to nothing, you've pretty-much ruined it (if that was the case).
yeller z06 is offline   Reply With Quote
Old 12-15-2011, 08:29 AM   #5
wayback
CF Senior Member
wayback's Avatar
Never heard of a starter causing a dead cell in a battery. They opposite? Yes.
__________________
2007 White/Cashmere coupe, 3lt,A6
1985 Red C4 Coupe 4+3
Gone but not forgotten:
1969 coupe custom gold and brown metalic
2000 c5 coupe VR/red
2005 c6 coupe 3lt VR/Cashmere
2006 Monty Red/ Cashmere/Beige Vert 2lt
wayback is offline   Reply With Quote
Old 12-15-2011, 08:38 AM   #6
Twisted1
CF Senior Member
I could see where it your battery was low, and lets say the motor was locked up and would not turn... It that case with the starter pulling a huge load and a weak battery I could see it taking out the battery. He does not have this situation, just saying there are ways to kill batteries.
Old 12-15-2011, 08:58 AM   #7
Larry/car
CF Senior Member
Larry/car's Avatar
A bad starter could damage the battery because of excessive high amperage draw. This could over heat the battery and warp the plates damaging a cell/cells. I any event the customer is going to have to talk the dealer into warranty replacement.
Larry/car is offline   Reply With Quote
Old 12-15-2011, 02:03 PM   #8
vettman96
CF Senior Member
vettman96's Avatar
No. The battery condition would effect starter rpm via reduced amperage available for the cycle, but starter condition would not drive a cell failure Cycle time during start is too short unless there is an imbedded defect in the battery.
vettman96 is offline   Reply With Quote
Old 12-15-2011, 02:23 PM   #9
cclive
CF Senior Member
cclive's Avatar
Quote:
cclive is offline   Reply With Quote
Old 12-15-2011, 03:33 PM   #10
madcadr
CF Senior Member
madcadr's Avatar
Dealership states that if the connection at the starter was loose - or if it had a bad solinoid - Then, yes it could cause damage to the battery (Or something like that - I am stating this the best way I can and I could have something not exactly right...)
They said they are testing the starter/solinoid to see if indeed something was wrong that could have damaged the battery.
Oh well, just curious - it is not the end-of-the-world...
However, if they do find where the starter caused the battery damage - Then, both are covered under GMPP.
I wish I still believed in Santa - I would just ask HIM to bring me a new battery...
Old 12-15-2011, 06:03 PM   #11
Vette5.5
CF Senior Member
Hard to say what really happened, as had new batteries that lost cells in just a few months. You didn't mention the battery you have, as if only 14 months, should be some kind of warranty coverage on it. I normally get Autozone or Advance Auto Gold series, as have 3 year free replacement.
Vette5.5 is offline   Reply With Quote
Reload this Page Could a bad starter cause a dead cell in battery?
Tags
amp, bad, battery, buys, c6, cell, cells, charge, damage, dead, fail, ruin, starter, starters, voltage
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
