rear lowering bolt install in 4 bolts or less
Actually its 2 nuts and 2 bolts with nuts. Decided to swap out my rear lowering bolts (i had cut mine too far and were noisy so i ordered new ones) the first time i did the rear i took the upper control arm loose and the shock as well. This time i took only the sway bar end link off and the 2 lower control arm bolts (marking the adjustment bolt to set the camber back where it was) ,,,, I didnt even take the tires off, lol.
Of course on a lift in my garage helps OH AND I KNOW THE ALIGNMNT IS WAY OFF RIGHT!!!! ACTUALLY BOTH REAR SIDES BEFORE AND AFTER WERE WITHIN ONE TENTH OF BEFORE I STARTED SO I FEEL COMFORTABLE ADVISING TO DO IT THIS WAY. Drive safe, paul
new lowering bolt in
