Thinking about buying a new Corvette? BEWARE!
#42
A few people have suggested that you change or look at the cabin filter. I would pay special attention to the cabin filter door gasket. This door is all there is between the engine compartment and the cabin air flow. ALL engines sweat a little oil and the heat of the engine will always cause under the hood to smell a little. A bad cabin filter door seal will allow the air under the hood to be sucked into the cabin especially when you stop.
#43
All this burning oil smell talk has me scared to do my first oil change.
#44
Go drive another new corvette grand sport and if it smells the same....your insane...if it doesn't smell the same then they need to figure out whats going on.
Seems like a fair way to go..
Anybody else smelling what you smell? Ie...GM area rep? Whats his sniffer saying?
Good luck.
What color and options are on the car.. ?? If its a manual Red 1 lt.coupe..maybe we can trade...
I have no sense of smell so it won't bother me. Mines a 2008 black Z51 1lt with NPP and a DSV Dshaped steering wheel...along with the glass top..
Good luck..
Good luck.
Good luck..
#45
I just had my oil changed yesterday and I also have the dry oil sump system. I drove 90 miles back to my home and never smelled any burning oil or such. I have heard a few horror stories about oil changes that were overfilled with this system.
#47
You must be one unlucky son-of-a-gun. I've NEVER had that happen.
#50
Good luck.
#51
I don't have a GS but did have some engine odors coming into the vent system. As was noted in an earlier post, check the cabin air filter access panel. Mine was not firmly in place and not making a good seal. Thing is it was not noticeable by just looking at it. Installed it correctly and odors stopped. Hope its that simple. I think its worth a check. Best of Luck.
#52
My car is a 2011 Grand Sport, 436 HP, automatic.
#53
try taking the car out at nite. run it till you get the smell. find a dark unlit location and shine a very brite but thin light all around the engine. If there is smoke, it will show up in the light. You might not see it in broad daylight. Even better if you can run the car w/o any lights on and/or on a lift so you can look under.
#54
Good luck.
Good luck..
Good luck.
Good luck..
#55
two weeks ago the dealership replaced my oil pan gasket... but for some reason i still smelled oil... went back to the dealership they put it on the rack and lifted it..the oil pressure sending unit seal/o ring is leaking it barely wet. but its enough that i could smell it.. i hope this helps those that smell oil. ill post pics later
#56
Please make sure there isn't any residual oil on your mats or in your carpet......Once years ago I spilled one ounce of fuel injector cleaner in the trunk carpet of a car and I smelled for a year inside the car...no matter how many times I washed it. Also even without the "air' filter you wouldn't smell burning oil from the engine compartment....the air inlets has always been in that general location and the "filter" is a relatively new deal...forget that filter.
There has to be oil somewhere...find it.
good luck.
good luck.
#58
Next time, I will mention it to the tech and stress that it better not happen again! Or change it myself . . . which is more likely to happen!!
#59
Received 8,960 Likes
Thanks to all of you for your responses. The dealer has removed covers, inspected and reinspected for leaks. They've changed the oil & filter again, introduced dye into the system, power washed at least twice, etc. There's no oil dripping anywhere. The smell seems to come into the car via the vent system. The area manager's been out. It seems that since they can't find the problem, the odor must be characteristic of the car, or so they say. They're telling me the smell might be coming from a burning sticker (i.e., on the catalytic converter), or from whatever constitutes the finish on hot metal parts. In my experience, those things can cause odor, but not of burning oil. That oil smell is like a skunk in the yard. Although you can't see it, you know it's there!
Bill
#60
Check the lemon laws for your state. In Utah more than 30 days in the shop within the first year is considered a lemon. It doesn't matter what they did with it in that time frame. My Envoy was in the shop for over a month. Part of that time was because they broke the window so they can get the key out of the car and then dented the door with the car seat. They also tried to fix it 4 times including one could not duplicate (which they didn't look at it too hard as I had it back in there the next day to show them the noise again).
GMC eventually bought back the vehicle after they screwed me around for 5 months. Once GMC found out about the dealer was flying me up to Wyoming to pick up my new vehicle and only charged me for wear/tear since the buyback process started 5000 miles ago.
