Crunching feeling in brake pedal
I was stepping on the brake yesterday at slow speeds and instead of the normal pedal feel (smooth, just increasing resistance), the pedal felt like I was pushing it through gravel - quick chattering through the pedal. Happened just a little bit through two pedal strokes and then it was gone. Felt the same thing once before (6 months ago?).
Anyone have any ideas what it could be? 2007 base coupe w/Z-51 package.
Definitely didn't feel like ABS kicking in - not really a pulsing. Was more like some type of drag or grit in the pedal travel. Very, very subtle. And it was at below 5 mph.. Just pull into a parking spot.
SoCal Events Coordinator
St. Jude Donor '12
If its not the abs and you felt it at slow speeds I'd guess you picked up some debris between the pads and the rotor or when was the last time you checked your brake pads? Have you worn them down to rivets or to the point of metal on metal?
I picked up a gravel size rock a few months back just driving down the road and it lodged between the brake caliper and the wheel. gouged the wheel a bit on the inside part of the wheel and made one heck of a noise. Once i came to a stop I guess the rock fell out as the noise had quit but the wheel damage was clear.
My brake pedal sometimes feels like I am pushing it through a layer of thin ice. Brake the ice and smooth again. That is on initial start up only. The....it's usually followed by Service Active Handling message. Not sure the cause, but it's starting to truly **** me off
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
It's just that last, very slow bit before you stop and it is like a "grunching" sound. I know it goes away, or has for me. If it stays, then it's something to look into more starting with the simple things. I might even hose out the brakes or pull the pads out to see after looking at the rotors first for any unusual wear pattern or grooves.
Then the rust was quickly removed by using the brakes a couple times.
Anyway, now it works normally, right? No DIC messages? No codes?
Same thing happened to me after each winter storage of my 09 Z51. No problem, no worries.
BTW, I mentioned "Z51" because that option includes larger cross-drilled rotors. I have no idea if that makes a difference... just sayin'.
I have had that happen to me a couple of times in 1.5 yrs of ownership. Last night after leaving work it was wet/cold (34 degeres) and when I was getting on the brakes it happened again for the first time in months so I think it was the ABS getting confused. I hate the nannies. Wish the car came without them. I don't like turning them off when I want to have fun. The first time I had this happen was right after I bought the car and I was traveling at a high rate of speed when I got on the brakes while turning and the pedal had all sorts of pulsating feedback coming back up through the pedal. It pissed me off and I wondered what kind of BS crap they were putting into these cars. If you can't control the car then get something else. This could be very dangerous in the wrong situation. BTW OP, those cases I got from you have worked out great. Thanks!
