Lowing my C6
Lowing my C6
Since I'm in the Midwest, I don't get to drive the car all year. I do however want to do some mods over the winter as time permits. Been reading several posts on lowering the car to take away some of the wheel well gap. Don't want to get too crazy but have seen some posts stating they have merely used the stock bolts, while others have purchased lowering bolts.
Suggestions?
Also, is this something that can be done in a typical garage over the weekend? Does anyone have a "how to" thread on this?
If I decide to do this, I will definately get an alignment once spring arrives......
Thanks for all the help.......
Suggestions?
http://forums.corvetteforum.com/c6-c...g-your-c6.html
This thread was started today - same topic..
Search using "lowering" in the General and Tech/Performance sections and you will get a million hits including how-to's complete with pics..
You can even google "lowering the C6 Corvette" and you will be directed to good links....
As always, your choice. But as you lessen the clearance should anythng be thrown up into the fender weld it's going to play hell on your plastic fenders. Might well do it any way but a little space sure can make a difference. God forbid you have a blow out ...
