"I don't have any more Wheelhop"
I would like to share my experience with the manuel guys experiencing wheelhop. When you try to smoke the tires to get better grip at the drag strip or street and you feel a bouncing or shaking inside the car. This bouncing can break parts and be very expensive. I had this issue and installed bilstein HD shocks, pfadt tranny mounts and Firestone wide ovals in the back. With all this I still had the dreaded wheel hop. But thru alot of research and actual practice, I decided to take the car out and practice with it.
What worked for me was to actual rev the motor between 2500-3000 rpms. But before that take your left foot and press the clutch all the way to the floor. Gradually slowly lift up to the point where it just engages where the car first wants to move. Stop. This point the actual point where the car very first wants to move. Then press gas between 2500-3000 rpms from the point where car wants to move where the clutch petal is, slowly lift clutch a lil more to where the wheels start to spin then squeeze the throttle even more and totally raise clutch fully.
This procedure worked for me. Its just slipping the clutch slowly. I feel I have eliminated it for my car. I still had it with all the parts named above. You dont want to accelerate it to 2500-3000 rpms and quickly release the clutch thats where the hop comes in. Its slowly releasing the clutch, and giving it more throttle. I just wanted to share for those still experiencing and maybe frustrated like I was. This what worked for me just to give some insights and information.
I posted the same thing a few years ago. The best way I describe it is that you are trying to not "shock" the tires by banging the clutch. You want to get them spinning somewhat gradually - it's all relative though. Its still a pretty quick release, but not a drop-clutch.
I believe Its gradual steps and more feeling of what the clutch and tires are doin. I would keep the rpms down. Just slowly lift the clutch. Thats what I would do.
2011 GS/6spd/F55 with 4k miles and I have never experienced wheel hop.
I've lit the rear tires up a few times from a dead stop, stabbed the gas from a rolling start and shifted up through the gears spinning tires, taken off quickly, etc... etc.... etc.... and have never had any issues with wheel hop.
I as many was very frustrated with wheelhop. But thru more research and actual practicing in vacant parking lots I feel I have mastered this.
I was very careful like others not to break anything. But I know this car has so much potential at the track and we need the grip from the tires to be heated.
The only way to achieve this was to start practicing on my own.
Also I would like to credit "Ranger" for his informative information regarding our cars. Also I dont know if this helps but, I always keep my clutch fluid clean per "Ranger". Mine is clear and not black.
With the clutch fluid clean, the clutch feels more sold and control. Also I wear thin shoes so I can feel what the clutch is doin in relationship to actual movement of the car.
Do believe Ranger has some good ideas on how to drive the car, but still believe there has to be a better way. Let's find a solution
Doing it too slow is an excellent way to burn out your clutch.
