Interior Lights Stay On
Old 10-13-2011, 02:32 PM
Peek
Peek's Avatar
Default Interior Lights Stay On
Okay I've had my used '07 3LT Vert for 6 months now with absolutely no problems - until today. The interior lights will not turn off after the time selected through the DIC (15 sec). All the exterior lights go out like they should, but the interior lights just stay on. I've opened/closed all the doors/hood/trunk numerous times, started the car, put the top up and down, even re-selected the time delay in the DIC - no joy. The lights (rearview mirror, footwell) will not go out.
Here's hoping someone else has had this little problem and found an easy fix. Thanks in advance.
Peek is offline
Old 10-13-2011, 02:33 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Push in and release the dash dimming switch at your left knee.
2007 owner's manual, page 171.
You can also turn the courtesy lamps on and off
by pressing the instrument panel brightness ****.
Vette_DD is offline
Old 10-13-2011, 02:36 PM
BEZ06
BEZ06's Avatar
You probably bumped the little push-button switch with your knee when getting in or out.
Check that switch - it's on the kick panel to the left of the steering column.
You can turn it to adjust the panel lights, but if you push it you get what you're experiencing.
Bob
BEZ06 is offline
Old 10-13-2011, 02:40 PM
NJLS708
NJLS708's Avatar
Bob
Very common
NJLS708 is offline
Old 10-13-2011, 02:57 PM
Daekwan06
Daekwan06's Avatar
Yep.. did this myself at the gym one day.
Woke up the next to a car that wouldnt start. Why they designed it that, I'll never understand.
Daekwan06 is offline
Old 10-13-2011, 02:59 PM
NJLS708
NJLS708's Avatar
Not sure why your battery would die. I think all interior and exterior lights turn off automatically after 10 minutes.
NJLS708 is offline
Old 10-13-2011, 03:08 PM
Peek
Peek's Avatar
Default Fixed it - don't know how, though!
I forgot to mention in the first post that I checked the "dome" light/dash light button/rheostat as well - turned on/off the lights with that while the car was running. Here's what I did, based on numerous other posts involving electrical gremlins - disconnected the battery, went and took a shower, reconnected the battery, started the car, played with all the lights again. When I shut off the car, got out, shut the door - the lights went out a few seconds after the exterior lights did. Oh, and I did remember to index the windows.
I understand systems - on aircraft. Except for electrical systems. When students asked me about something electrical and how it worked, I always responded "magic".
Thanks everyone for replying to the post. Doesn't everyone work?
Peek is offline
Old 10-13-2011, 03:20 PM
Vette_DD
Vette_DD's Avatar
Could have saved yourself the trouble if you'd posted first, then waited 5 minutes to watch for answers.
Vette_DD is offline
Old 10-13-2011, 03:27 PM
mundo
mundo's Avatar
You bumped the button next to your left knee. Depress it once. Close the doors. The lights should go off in a few seconds. If not check the lights in the rear view mirror. Believe it or not they turn off by depressing in. You'd think it was the opposite. I've been bitten by this too.
mundo is offline
Peek
Peek's Avatar
Default Patience, Patience
Yep, I could have waited a little while - I honestly didn't think the excellent replies would be posted so quickly - and I was worried the battery would go dead anyway. I was gonna wait at least a few hours before checking for replies, but when I reconnected the battery I came back inside to see all these replies. Wow.
Lesson learned, and thanks again everyone for the replies.
Peek is offline
abda53
abda53's Avatar
Classic newbie mistake!
abda53 is offline
Old 10-13-2011, 03:34 PM
SpryGeezer
SpryGeezer's Avatar
I put a nylon lock collar on the left knee interior light button because I never missed. It won't go in or on accidentally now. Forgot the button diameter.
SpryGeezer is offline
Old 10-13-2011, 04:03 PM
Vette_DD
Vette_DD's Avatar
I'd say about 80% to 90% of us have done this at least once. I did it about 2 months ago, after having had C6s for 7 years and posting here about it approximately 15 to 20 times.
Vette_DD is offline
Old 10-13-2011, 04:04 PM
NJLS708
NJLS708's Avatar
Originally Posted by JimTN
I'd say about 80% to 90% of us have done this at least once. I did it about 2 months ago, after having had C6s for 7 years and posting here about it approximate 15 to 20 times.
I did it two days ago
NJLS708 is offline
Old 10-13-2011, 04:18 PM
Thrash
Thrash's Avatar
Also on the rearview mirror map lights, the buttons are ***-backwards ... pushed out is "on" and pushed in is "off" ... WTF w/that?
Thrash is offline
Old 10-13-2011, 04:23 PM
speedraider
speedraider's Avatar
we have all done it.
speedraider is offline
Old 10-13-2011, 07:09 PM
Peek
Peek's Avatar
Default Thanks
Thanks again for all the responses. Have a great day! Or night!!
Peek is offline
To Interior Lights Stay On
Old 10-13-2011, 07:17 PM
z06clif
z06clif's Avatar
We've all done it.
Clif
z06clif is offline
Old 09-23-2012, 03:11 PM
minitrax23
2nd Gear
minitrax23's Avatar
Thank you soooo much! I was going crazy trying to figure this out.
minitrax23 is offline
Old 09-30-2012, 02:26 PM
Airstream87
3rd Gear
Airstream87's Avatar
Default Lights
Glad I joined had same issue, question the switch is the dashboard dimming switch, right.
Airstream87 is offline
Quick Reply: Interior Lights Stay On
