Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-12-2011, 04:51 AM   #1
Triumph Jerry
CF Senior Member
Triumph Jerry's Avatar
Default Set parking brake properly....
If this saves someone a lot of grief, it's worth the post.
To set the corvette parking brake, have engine running,
push the brake pedal normally, while lifting the parking brake all
the way up.
I see many people just lift the lever, engine off and no brake pedal.
The brake pedal sets the brake tension.
Sorry for the boring thread.
....jerry
Triumph Jerry is offline   Reply With Quote
Old 10-12-2011, 05:05 AM   #2
Swiftrider08
CF Senior Member
Swiftrider08's Avatar
Not sure where you got this information, but not correct at all. The brake pedal/system in the C6 is not tied to the emergency brake in any way. Two independent systems.
Swiftrider08 is offline   Reply With Quote
Old 10-12-2011, 05:17 AM   #3
Triumph Jerry
CF Senior Member
Quote:
The pedal puts pressure on the rear pads, the lever puts pressure
and holds the pads against the rotor.
Using the lever alone a woman would not get enough pressure to
hold the car.
Old 10-12-2011, 05:21 AM   #4
Triumph Jerry
CF Senior Member
...and it's NOT an emergency brake it's a parking brake.
Old 10-12-2011, 05:25 AM   #5
MikeyTX
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
MikeyTX's Avatar
Sorry, o/p is right, you are wrong. Read section 9-35 of the owners manual. It states exactly what the o/p has stated. http://www.chevrolet.com/assets/pdf/...ner_Manual.pdf
__________________
Bearcreek, MT Sept. 2012 across from the Hungry Bear Cafe. Great eats, great hosts.
MikeyTX is offline   Reply With Quote
Old 10-12-2011, 05:26 AM   #6
Swiftrider08
CF Senior Member
hold the car.
You don't understand how the "parking brake" works on the C6. There is a small set of actual "brake shoes" inside the rear rotors that are the parking brake. The actual pads have no connection to the parking brake itself. You should do a little research to educate yourself on the brake system of the C6.
And while driving, if your main brakes fail, you would be calling that an "emergency brake"!
Old 10-12-2011, 05:32 AM   #7
Swiftrider08
CF Senior Member
Quote:
That is to keep the car from moving while you are setting the parking brake. The two systems are independent.
Old 10-12-2011, 05:38 AM   #8
Triumph Jerry
CF Senior Member
From the Corvette C6 manual....
The parking brake lever is located
to the right of the center console.
To set the parking brake, hold the
brake pedal down. Pull the parking
brake lever up. If the ignition is on,
the brake system warning light will
come on.
To release the parking brake, hold
the brake pedal down. Then push
the release button in as you move
the parking brake lever all the
way down.
Can't you just go away?
Old 10-12-2011, 05:42 AM   #9
Swiftrider08
CF Senior Member
come on.
way down.
That means nothing in trying to prove your point. Your just making a big assumption. Like I said, that is to keep the car from moving while you set the parking brake. Safety first. The same for when you release the parking brake. Hold the brake pedal down so the car does not roll when you release the parking brake. The two systems are not connected.
Here are the parts: http://store.gmpartshouse.com/partlo...layCatalogid=0
And no, I won't go away!
Old 10-12-2011, 05:52 AM   #10
WAwatchnut
CF Senior Member
WAwatchnut's Avatar
come on.
way down.
You're correct that this is what the manual says to do, but I don't think youre correct when you say "the brake pedal sets the brake tension". I appreciate you're wanting to warn people, but if you're giving them incorrect information, it's worse than not saying anything at all.
Why would you want someone to just go away when they're trying to correct the wrong info? Are you really trying to help people? If so, let's make sure it's the right info!
The manual also says you should park manual transmission vehicles in reverse... And then people go and say "it's to prevent DBS", when it's really just because it's safer to park with the tranny in reverse (especially with the weak parking brake!).
I believe the parking brake system is separate, and pushing the break pedal when setting the p-brake doesn't change the p-brake engagement at all. But I'm really happy to learn the facts!
WAwatchnut is offline   Reply With Quote
Old 10-12-2011, 06:22 AM   #11
Swiftrider08
CF Senior Member
If there is something here that I am wrong about, no problem admitting that. It's all about education.
Old 10-12-2011, 06:26 AM   #12
R&L's C6
CF Senior Member
R&L's C6's Avatar
That is my understanding also.
R&L's C6 is offline   Reply With Quote
Old 10-12-2011, 06:29 AM   #13
rgauchey
CF Senior Member
rgauchey's Avatar
rgauchey
Send a message via ICQ to rgauchey
I believe the owners manual wins this one.
rgauchey is online now   Reply With Quote
Old 10-12-2011, 06:32 AM   #14
Swiftrider08
CF Senior Member
Quote:
Explain why you think that.
Old 10-12-2011, 06:33 AM   #15
Swiftrider08
CF Senior Member
Here is a good thread on the subject from 2007. Same braking system today.
http://forums.corvetteforum.com/c6-c...rake-work.html
Old 10-12-2011, 07:41 AM   #16
NJLS708
CF Senior Member
NJLS708's Avatar
come on.
way down.
You hold the brake pedal to hold the car in place while you set the parking brake. The parking brake is not tied to the regular brakes in any way. Two totally independent systems. And its not nice to tell someone to go away when they are correcting your mis-information. I believe an apology is in order.
NJLS708 is offline   Reply With Quote
Old 10-12-2011, 07:47 AM   #17
REVAK
CF Senior Member
REVAK's Avatar
The C6 disc brake system and the parking / emergency brake are completely independent. The only common components are the rear brake rotors as the parking brake drums are integral with the rotors. Years ago there were many makes and models with 4 wheel disc brakes that did have the parking brake mechanism built into the caliper / pad / rotor assy. That system did not work very well , and now virtually all 4 wheel disc brake equipped cars and light trucks employ the separate system via integral drum. The owners manual does not imply otherwise. What it states is for the purpose of not abusing the drum portion of the system, I E , stop all motion / inertia with the hydraulic disc system, then hold the vehicle with the separate hand brake.
REVAK is offline   Reply With Quote
Old 10-12-2011, 07:50 AM   #18
GOLD72
CF Senior Member
GOLD72's Avatar
Quote:
I think the GM lawyers wrote that passage in the Owners Manual. I think we have all seen that with cars and other products over the past several decades. The corvette disc brake system since the early 60s has always used an independent set of drum shoes for the rear parking brake. I replaced my own on my 72 shark that I owned for 34 years.
__________________
GOLD72
1972 WB Coupe L48/TH400 - Sold
2001 QS Z06 - Sold
2006 VY Z06 - NCM Delivery - Sold
2007 MR Vert - NCM Delivery & Wife's Garage Queen
2010 Vanilla Latte CTS 3.6L Sport Wagon - Wife's DD
2011 AW ZR1 - NCM Delivery & Daily Beater
GOLD72 is offline   Reply With Quote
Old 10-12-2011, 07:51 AM   #19
AORoads
CF Senior Member
AORoads's Avatar
I agree! For those who would like to understand the system, look at that thread, especially talon90's picture in post #6. And then look at dave pawlowski's explanation in post #28 (he has other good explanations in that same thread).
Forget the other bs about "feelings" and "this is what I remember about my 1980s car" and cut to the important posts.
AORoads is offline   Reply With Quote
Old 10-12-2011, 08:08 AM   #20
jschindler
CF Senior Member
jschindler's Avatar
I agree completely with what you have been saying. They are two separate systems. Holding your foot on the brake has nothing to do with the engagement of the e-brake.
__________________
Jim
SOLD FEB 2012 - NO LONGER A CORVETTE OWNER, out riding my motorcycles
Previous Corvettes: 94 Coupe, 01 Coupe, 03 Vert, 05 Coupe, 05 Vert, 08 Coupe, 09 Z06
Current daily drivers: '12 BMW 550 M-Sport (Mine), 14 Lexus GS350(wifes)
Current toys:13 BMW K1600 GT, 12 Ducati Panigale, 11 Kawasaki Ninja 1000
jschindler is offline   Reply With Quote
Reload this Page Set parking brake properly....
Tags
72, brake, c6, corvette, emergency, indicator, light, manual, o3, parking, proper, properly, replacement, reverse, set, transmission, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
