Set parking brake properly....
If this saves someone a lot of grief, it's worth the post.
To set the corvette parking brake, have engine running,
push the brake pedal normally, while lifting the parking brake all
the way up.
I see many people just lift the lever, engine off and no brake pedal.
The brake pedal sets the brake tension.
Sorry for the boring thread.
....jerry
the way up.
....jerry
and holds the pads against the rotor.
Using the lever alone a woman would not get enough pressure to
hold the car.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
And while driving, if your main brakes fail, you would be calling that an "emergency brake"!
Sorry, o/p is right, you are wrong. Read section 9-35 of the owners manual. It states exactly what the o/p has stated. http://www.chevrolet.com/assets/pdf/...ner_Manual.pdf
The parking brake lever is located
to the right of the center console.
To set the parking brake, hold the
brake pedal down. Pull the parking
brake lever up. If the ignition is on,
the brake system warning light will
come on.
To release the parking brake, hold
the brake pedal down. Then push
the release button in as you move
the parking brake lever all the
way down.
Can't you just go away?
From the Corvette C6 manual....
come on.
way down.
come on.
way down.
Here are the parts: http://store.gmpartshouse.com/partlo...layCatalogid=0
And no, I won't go away!
come on.
way down.
come on.
way down.
Why would you want someone to just go away when they're trying to correct the wrong info? Are you really trying to help people? If so, let's make sure it's the right info!
The manual also says you should park manual transmission vehicles in reverse... And then people go and say "it's to prevent DBS", when it's really just because it's safer to park with the tranny in reverse (especially with the weak parking brake!).
I believe the parking brake system is separate, and pushing the break pedal when setting the p-brake doesn't change the p-brake engagement at all. But I'm really happy to learn the facts!
You're correct that this is what the manual says to do, but I don't think youre correct when you say "the brake pedal sets the brake tension". I appreciate you're wanting to warn people, but if you're giving them incorrect information, it's worse than not saying anything at all.
If there is something here that I am wrong about, no problem admitting that. It's all about education.
You don't understand how the "parking brake" works on the C6. There is a small set of actual "brake shoes" inside the rear rotors that are the parking brake. The actual pads have no connection to the parking brake itself. You should do a little research to educate yourself on the brake system of the C6.
Here is a good thread on the subject from 2007. Same braking system today.
http://forums.corvetteforum.com/c6-c...rake-work.html
come on.
way down.
come on.
way down.
The C6 disc brake system and the parking / emergency brake are completely independent. The only common components are the rear brake rotors as the parking brake drums are integral with the rotors. Years ago there were many makes and models with 4 wheel disc brakes that did have the parking brake mechanism built into the caliper / pad / rotor assy. That system did not work very well , and now virtually all 4 wheel disc brake equipped cars and light trucks employ the separate system via integral drum. The owners manual does not imply otherwise. What it states is for the purpose of not abusing the drum portion of the system, I E , stop all motion / inertia with the hydraulic disc system, then hold the vehicle with the separate hand brake.
You hold the brake pedal to hold the car in place while you set the parking brake. The parking brake is not tied to the regular brakes in any way. Two totally independent systems. And its not nice to tell someone to go away when they are correcting your mis-information. I believe an apology is in order.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Forget the other bs about "feelings" and "this is what I remember about my 1980s car" and cut to the important posts.
I agree completely with what you have been saying. They are two separate systems. Holding your foot on the brake has nothing to do with the engagement of the e-brake.
