Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-03-2011, 07:44 PM   #1
Cypher
CF Senior Member
Cypher's Avatar
Default OEM Carbon Fiber Z06 Hood?
What is the actual weight savings with the carbon fiber hood…is it significant or is it just one of those “wow, that’s cool” kind of options?
I’m looking at 2 different Z06 Centennials…one with the CF hood and one w/o. Trying to decide if I should pay for the CF or not. Just a street car, will never see the track (well, maybe the occasional drag strip).
The $2500 doesn’t really matter much, but then again, why pay for something I may never appreciate. Do both hoods look the same as far as external appearance?
Opinions?
__________________
2012 Z06 Centennial 3LZ CFZ B92
Cypher is offline   Reply With Quote
Old 10-03-2011, 07:54 PM   #2
talon90
Moderator
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Support Corvetteforum!
talon90's Avatar
The carbon fiber hood on the Carbon Edition Z06 reduces the weight from a stock Z06 hood by 11.5 pounds. The carbon fiber hood looks more like the ZR1 hood as it has the same slight height increase over the stock Z06 hood it doesn't have the polycarbonate window in the center. The Carbon Edition hood shares the same inner skin as the ZR1 hood but has a model specific outer skin with the slight higher rise.
talon90 is offline   Reply With Quote
Old 10-03-2011, 08:09 PM   #3
Cypher
CF Senior Member
Cypher's Avatar
Quote:
Thank you...very good info.
So, then this would be the CF hood, correct?
Click the image to open in full size.
Old 10-03-2011, 08:18 PM   #4
talon90
Moderator
NCM Ambassador
talon90's Avatar
Not likely. That's the Centennial Edition. Here is the Carbon Edition hood:
Old 10-03-2011, 08:32 PM   #5
Cypher
CF Senior Member
Cypher's Avatar
The Centennial Edition is what I’m looking at. There’s a $2495 Carbon Fiber hood option for the Centennial that’s separate from the $3995 Carbon Fiber Package (splitter, rockers, roof & ZR1 spoiler).
I’m trying to determine if the Centennial Edition Carbon Fiber hood looks any different than the standard Z06 hood.
Old 10-03-2011, 08:44 PM   #6
talon90
Moderator
NCM Ambassador
talon90's Avatar
Yes, it looks considerably different in person. It will look exactly like the hood in the two photos that I posted above. Note the large flat area in the center (where the window would be on the ZR1). You can also just see the regular Z06 hood (on the Grand Sport Convertible in the background as the regular Z06 hood is the same as the base coupe and Grand Sport hood.
Old 10-03-2011, 09:04 PM   #7
JoesC5
CF Senior Member
Yes, that is the carbon fiber hood option.
JoesC5 is offline   Reply With Quote
Old 10-03-2011, 09:08 PM   #8
Snake.Oiler
CF Senior Member
St. Jude Donor '13, '14
Snake.Oiler's Avatar
Correct.
Snake.Oiler is offline   Reply With Quote
Old 10-03-2011, 10:32 PM   #9
0Halltech
Former Vendor
St. Jude Donor '09
Halltech's Avatar
Halltechsystemsllc
This is the lightest carbon fiber hood available for the C6. All carbon fiber, and clear coat bottom. 13.5lbs
Molded from the Z06 Carbon high rise hood, but with a Direct Radiator Exit Ducting for much cooler coolant temps.
More pics:
http://www.halltechsystems.com/Photo...roductCode=GT2
MORE
Halltech is offline   Reply With Quote
Old 10-04-2011, 08:18 AM   #10
Cypher
CF Senior Member
Cypher's Avatar
Thanks all…I believe I have the info I need now.
While I like the exterior appearance of the CF hood, I’m not quite sure I’m good with the added hood height from an interior point of view. I’m very comfortable with the hood on my current coupe from the driver’s seat and not sure I’d want the hood to extend any higher into my forward visibility.
Since I will not have the opportunity to actually sit in a Z06 with the CF hood before I finalize this deal, I think I will opt for the standard hood for now since I know I’m good with it. A new hood is always an easy mod down the road if I want to try a different look in the future.
__________________
Old 07-19-2014, 02:43 PM   #11
trueblue04
Junior Member
Does anyone have a 2004 commemerative edition hood for sale?
trueblue04 is offline   Reply With Quote
Reload this Page OEM Carbon Fiber Z06 Hood?
Tags
c3, c5, carbon, corvette, fiber, fiberz06, hood, oem, parts, roof, stock, weight, z06, zo6, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
