Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- C6 Corvette: How to Repair Your Ashtray Door
Step by step instructions for do-it-yourselfers...
bogus ash tray (MERGED)
Help !!!! I can't get my ash tray to stay closed. Just how much of the dash...if any...has to come out to have a look-see at the ash tray mechanism. Any help would be greatly appreciated.....thanks all.
I'm posting this often used thread link but now I see the pictures are gone!
http://forums.corvetteforum.com/c6-c...iy-w-pics.html
You don't have to remove any of the dash/console. The ashtray door can be popped out by itself. Maybe you can deduce the issue from the word descriptions in the above thread. If not, maybe someone else has some pics. Good luck.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Its a brutally easy fix....Take the ashtray out take a small piece of hard plastic and super glue it to the tab that the clips grab to open close the ashtray...just take a dremil and make that plastic piece a little bigger and wider so the clips grab it securely...promise it will work...did mine a year ago and never had a problem since!
NCM Lifetime Member
Someone uses the ash tray ?
Glue the damn thing shut
Seriously someone needs to come up with an alternative use for the door. I'm sure plenty of Corvette owners would love to have something there besides an ashtray and lighter. I took mine apart and messed with it and it stays shut now.
Here are two photos that had been originally posted by member nhisfan:
First photo shows how to remove the ashtray door. Pry from the right side with a flat blade screwdriver.
Second photo shows the door striker which gets worn down, causing the problem. The striker head needs to be restored by adding some epoxy to it, then filed to shape.
Should be an easy fix, just make sure to prep the striker head properly, rough up the surface, clean it well with alcohol and then use a good epoxy like JB Weld or similar.
Here's the original DIY ashtray door fix thread by nhisfan:
This may not be the ultimate ashtray door design, nor is implemented with a high degree of quality.
However, we mustn't forget the absolute genius of the overall design of the C6: very low weight, 50/50 weight distribution, ultra low drag coefficient, loads of naturally aspirated horsepower and neck snapping torque, incredibly impressive MPG considering, ultra quiet, smooth, refined ride, killer handling, extreme comfort, I could go on and on.
The C6 is an all-purpose street car that you could drive to work each day or drive cross-country in great comfort, yet take to a track and spank the greater percentage of other expensive, respected high performance cars from all over the world.
And in my opinion, the C6 is one of the best looking cars ever made (except for maybe the C2 Corvette).
The C6 is quite an impressive package overall. And, in most cases, a C6 coupe is maybe 75% or 50% of the cost of other high performance cars that come anywhere close to matching the C6's overall combined abilities.
The point is, yes, the C6 has a few cheap, less than ideal designs / implementations (like the ashtray door), but I'm not thinking about the ashtray door while I'm passing a $100k Porsche on a twisty mountain road in my $50k C6 coupe, and then afterward getting 30 mpg on the hwy with my 400 horse, 6.0 liter V8 while riding in living room comfort in a car that is drop dead gorgeous.
I accept the minor "deficiencies" of the C6 as a trade for an absolute top-notch, ultra high performance car that does it all, and does it all WELL, at half the cost of much of the competition.
It'll probably take me about 30 minutes total to fix my ashtray door (minus epoxy dry time), a very small price to pay considering all. The ashtray door held up just fine for the first 5 years anyway. I can live with that. No need to kill the bean counters.
CF Senior Member
Ash Tray Door Issue (Again)
I never use my ash tray on my 2008. The POS door will not stay closed. I had this happen on my 2005 and it was fixed under warranty. I have a GMPP, but my dealership told me is not covered. I did a search on this forum. There is a DIY to fix this, but all the pictures are gone. Is there a safe way to remove the door without having to remove the whole console? The mechanic at the dealership told me I must take the whole center console and bezel apart to fix this issue. GM should be highly embarrassed by the quality of this piece. I would of gladly paid $10 extra for my car to have something that worked as designed, especially if never used.
SUBVETTE
You have to remove the entire console bezel and then replace the whole ashtray assembly. Not that difficult if you are a DIY person. I had the same issue on my 06 and bought a new ashtray from www.gmpartshouse.com and put it in. If you have heated seats you have to swap the switches to the new piece too.
http://forums.corvetteforum.com/c6-c...-ash-tray.html
CF Senior Member
Member 'Vet' resurrected those pics in this thread, post #9. No need to remove the console if you want to attack it this way.
I was able to release the right side, but the left side will not come loose. I do not want to break it.
1 Post
I like the way you think
You can replace the entire assembly at a reasonible cost. While not ideal, it gets the job done.
FWIW, this is a poor design but I still love my C6!
Last edited by Vette_DD; 10-02-2012 at 05:56 PM. Reason: Link to non-supporting vendor
CF Senior Member
FWIW, I love my Z06, but love it even more when every single thing on it is in perfect working order.
Last edited by Vette_DD; 10-02-2012 at 05:57 PM. Reason: Link to non-supporting vendor
