xm radio gets no signal after battery disconnect
car was in the shop for repair after we got rear ended.. repair looks good but on the way home the xmradio reception was cutting in and out. I reset it myself by calling xmradio and having the reset signal sent. Now I get no signal at all.
So I call XM support and they try a few more resets with no results.
I was told because the battery was disconnected I need to take it to the dealer to have the xm module reset.
Anyboby had this happen to them?
Thanks.
Thanks.
2019 Z06 2LZ A8 Coupe
The XM radio module on coupes is located in the left side of the cargo area. Is it possible the antenna cable was either unplugged or damaged in the accident or repair?
So the module itself if on the left rear side of the cargo area...
Here's a link to Kawal's excellent documentation for installing GM PAL units. These instructions will help you pull out the XM Radio module and check the connections.
http://www.kawal.net/PAL%20rev2%20install.htm#Option 1
The main guy said the mechanic told him the only cable going back there was to the lights but this makes more sense... That might be the case on the right side, but obviously the xm module is there as well.
Thanks again.
Wanted to bump this one up. OP, did you ever get yours fixed? I tried to activate my XM today on the used 2005 c6 I bought, and I'm getting no signal on my XM. I pulled the receiver and verified the connections are good. Still no signal. Any help?
I did the same and all connections looked good. I'll let you know.
Do you get any sound on channel 1? I'm pretty sure we are supposed to even if we don't have a subscription.
Also, I did have customer support do a couple of hard resets that they thought might work - you may want to try that as well. At least to feel like you've tried it all.
I'll let you know when I see what the verdict is with mine.
By the way, congratulations on the purchase! My 2007 was my first and I fall in love again every time I drive it.
I like the color (it looks silver like mine)
The antenna for the xm radio, at least in my 2007 coupe, is in the right mirror of all places.
It will get fixed under extended warranty. They'll call after part comes in and they paint it.
I'll keep you posted.
I get a call from Carol at the dealer - "You need a new right mirror...".
Received 2,051 Likes
St. Jude Donor '13
Experts will be along soon to confirm or deny that.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
