"Battery saver active"
Old 09-21-2011, 06:14 PM
cclive
cclive's Avatar
Mine is a stick and pushing the top of the button without pushing in the clutch turns on the ignition also....ignition on but no engine start. Maybe an automatic is the same if you don't hold the brake.
Old 09-21-2011, 06:23 PM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Nope. With an A6 you just get the message to put your foot on the brake when you press the top. You have to press the bottom.
Quick Reply: "Battery saver active"
