New Wheels, now have vibration
#41
This article from the forum will explain the offset better... http://forums.corvetteforum.com/c6-c...oupe-help.html
#42
with everything you said
It's the same reason I simply bought a second set of Stock Gumby's to mount some Michelin A/S tires on.
After looking at new wheels for a year, the only place I found that knows what their doing with Offsets that work the way they are supposed to is CCW. Complete Custom Wheels.
I couldn't find any other custom wheels that offered the Same Offsets as the Stock wheels.
Every time I saw a picture of some wheels I liked they didn't fit under the car correctly.
They looked like the rear wheels on the OP's car.
Sure, there are a lot of custom wheels that work even though the Offsets are not correct.
But why have that
gp56, I hope you get everything worked out to your satisfaction
But why have that
#43
#44
New to the board, just ordered a new GS, got stock wheels because I want to get custom's. Am having questions and concerns about the fit, offset, concentricity, tire rubbing, etc., and by reading this post, I can see my questions and concerns are valid. Looks like one really needs to be careful, one size does not fit all. I'm looking forward to the resolution to this problem, I hope it works out for gp56 in the end. The people on this board are great. everyone's really helping gp, and it's a great that we use this board in this way.
#45
#46
Was more to the fact of the explanation of the offset. Stock rim offsets Front: 18 x 8.5 56MM offset Rear: 19 x 10 79MM offset The "offset" is defined as the distance from the centerline of the wheel to the hub which bolts on to the axle assembly. The offset can be positive or negative, positive being to the face of the wheel, negative to the back of the wheel. Offset will change depending on the design of the wheel. All things being equal the face of the rear wheel with a 65MM offset will "stick out" about 1/2" more then the stock rim (79MM-65MM=14MM x .04 = .56") still dependent on wheel design. If you use your stock tires, it will be hardly noticeable. Still a matter of taste when it comes to wheel and tire appearance. As long as a wheel fits with no interference and the tire is mounted properly to a rim width within it's suggested size range, then it is a "correct" fit. Only "incorrect" if it does not mechanically fit/function. Credit to RBYCC
#47
I didnt mind the extra 1/2, but when I started hearing the scraping noise that was unacceptable. Right now I am hoping that they have a C6 rear wheel and they sent me a C5 wheel as NCVette pointed out. Website is confusing as it states that they are available in both C5 and C6 offsets but the specs state a 65 mm offset. They were told the car was a 2006 so you would assume they would send the right ones. Hope to get answers to this from them tomorrow. Appreciate the info, I would not have thought that the 1/2 inch would have caused a rubbing issue.
#48
Received 2,491 Likes
St. Jude Donor '15
"In honor of jpee"
My suggestion to you is: no, the two wheels that have been compensated for by balancing MAY become a problem somewhere down the road. You need two more wheels that are round to start with so that months or years down the road when you can't go back and ask for new wheels.....
Also, as to your pic (which you should send to wheel etailer) and what 3Gen said, that does not look right. Splitting the difference betw. C5 and C6 is poor product design. Not apples to apples, but what's betw. a V6 and a V8? A V7? I don't think so.
Get the right wheels, no matter who makes them, at the right size that are also true and round, too. Don't compromise.
Remember: there is only about ONE 8 1/2" by 14" piece of paper's total footprint of rubber connecting you to the road. That's all 4 tires combined, not just one. And guess what your tires are riding on--wheels?
As per boomer, that is the reason I went with gumbys, too.
Tell us how it all turns out. And good luck.
#49
I've got an 08 Tahoe Hybrid that had the exact same problem you have after I had a set of Boss wheels intsalled. Had the tires balanced several times, finally I took it to a different shop. They took one look and said I needed a set of concentric hub rings. I had never heard of them. Apparently some wheels don't fit exact on the hub. The concentric hub ring centers the wheel exactly........It solved my problem for about $40
#50
#51
Just got off the phone with WCC. There is not a wheel for a C5 and a C6. They use the same rear wheel for both. Guy said that the right rear wheel, even with OEM wheels on a C6 always sticks out more than the left side, so that, coupled with the 14 MM difference in offset is what I feel is causing my issue. He said this is the first time someone complained about scraping. He asked me to send him pics. The only one I had on hand was the one that I posted earlier in this thread. Will have to take additional ones when I get home tonight. He said they may have to send me another set of rears, and I asked what will that do if the offset is the same...
As for the two left wheels being slightly out of round he noted that on his end so that if I ever have problems in the future they are aware of it. Didnt complain about this as my focus right now is on the rears...
#52
Well, at least that answer is consistent with what they also told me as stated in my prior post. They are certainly good looking wheels, but of course you also want them to fit properly.
Hope it gets worked out to your satisfaction.
#53
They requested additional pics from the top down and from the side. Will take more tonight.
I do have chrome hub covers on my rotors. They are only about 1/16 of an inch thick, which would be 1.5MM. I hope that they are not contributing to this. They are a bitch to get off to test as the rear caliper brackets need to be removed. Had to go to my mechanic to get them installed initially.
#55
Question for all of you. If raising the rear height by 1/4 to 1/2 inch and/or cutting the wheel well liner near the lip of the fender by about an inch stops the scraping would you do it?
I like the look of the wheels, had repro spyders as my second choice and Gumby's as my third but I felt these had a more unique look. Just took off the chrome 5 spokes when I put these on and felt the Gumbys were too similar.
#56
I might get banned for this, but to me that is not acceptable. The rears on a C6 need different numbers than a C6.. To me that is like saying here use these mustang wheels on your Supra, they have the same bolt pattern so they'll work.. right??
We put 11" wheels with 325 tires on the back of C6' lowered, so no you should not have to raise car, cut, roll or beat fenders to make 10" wheels fit.
Just my 2 cents.. Fire away..
Melissa
CCW
Melissa
CCW
#57
Melissa
CCW
Melissa
CCW
#58
Besides that,you are going back to the 1970's look of cars jacked up with air shocks and wheels that stick out too far.Not a good look then or now.
Just get the correct size wheels.
#59
Melissa
CCW
Melissa
CCW
#60
St. Jude Donor '15
"In honor of jpee"
only you can make the decision but my recommendation above still stands. obviously, some are of the same/similar opinion.
