Anyone change their own oil in dry sump system?
I always change my own oil. Now I have a 2011 Grand Sport with dry sump. Anyone out their know where I can find a step-by-step how to on how to change the oil and filter? I probably could figure it out but I want to be sure. Pictures would help. Thanks for your help.
I think it tells us how to do it right in the owners manual. I will be doing this for the first time as well pretty soon too!
Look on page 10-19 of your owners manual.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Here is the Z06 procedure, I haven't seen the GS dry sump oil pan so I am assuming they are the same. Make sure you know the correct drain plugs when you do this. I won't be held responsible, YMMV, RTFM, etc etc etc. http://forums.corvetteforum.com/c6-z...il-change.html
Last edited by ByByBMW; 09-16-2011 at 06:17 PM. Reason: added link for clarification
It is the same, just do both drain plugs: They are close to each other on the oil pan (or where it would be, if the engine wasn't dry sump).
One plug just drains whats in the bottom of the motor, about a quart, and the other drains the dry sump tank.
Here is a pic of both drain plugs, the filter, and the oil lines. You are looking from the front to the rear. Drain one plug at a time, otherwise a mess is without question. Be prepared to catch around 10qts! Also, you'll notice that up top you have no traditional oil fill. On passenger side there is a cannister to fill instead. See both pics below. The lines themselves hold some oil that won't come out, but it's not worth disconnecting them. I did for my header installation and made a mess thinking all the oil was out.
Lifetime NCM Member #2497
Instead of 1 plug you have two as mentioned above. It just takes more time draining and extra time to put the 10.5 quarts in. Not much different than a normal oil change.
Its in your owners manual. I have a 08 DD Z that I do my own oil changes on. Other than the things already mentioned, when you re-fill it keep a quart out of the car. Start it and let it run for a minute. Shut it down and add the last quart then check the level. You can overfill the reservior since the oil doesnt get into all the places it supposed to be until you run the motor.
Its as easy as changing the oil in a wet sump car except that you have two drain plugs and need a huge drain pan.
I AM ON MY 4TH OIL CHANGE, DO IT EVERY 5K JUST FOLLOW THE MANUAL AND IF YOU DECIDE TO HAVE SOMEONE ELSE DO IT SHOW THEM THE BOOK AND POINT TO THE SECTION AND SAY READ IT FIRST AND DONT MESS UP.
Caution - Oil change in progress!
Be very careful if you have someone else change your oil!
I recently received a PM from a 2011 Grand Sport owner that had his oil changed. The business neglected to drain both plugs and the result was a massive overfill. Last I heard is that he has a bent connecting rod and will receive a new replacement engine. A very costly mistake...
Also make sure you allow ample time for the dry sump to drain. All the more reason to do it yourself, as most businesses want things done as quickly as possible.
Here's a view from inside your dry sump oil pan:
