Gas smell
Old 09-04-2011, 06:30 PM
Dennis08
Dennis08's Avatar
Default Gas smell
Hello all. I have a 2008 Base, C6 auto. I have the smell of gas coming from the drivers side wheel well area, as well if you sit in the driver's seat you can also smell it. I searched the entire car and can not locate a leak. I bought a new gas cap in hopes that would solve the problem, but it did not. I searched the form and located similar problems but all were on 2004's with the defective crossover pipe GM has since changed, and I have not over filled the tank. Any suggestions to this problem???? Thanks
Old 09-04-2011, 09:16 PM
DigitalWidgets
DigitalWidgets's Avatar
Diet? Beanno or perhaps Gasex?
Although, if the smell is gasoline, I got nothing for ya!
Old 09-04-2011, 09:25 PM
laconiajack
laconiajack's Avatar
All I know is that I wouln't continue to drive a car that smelled of leaking gas. I would have it transported to my nearest Chevy dealer and tell them to fix it.
Old 09-04-2011, 10:03 PM
Rebel 1
Rebel 1's Avatar
Did you buy the car new or used? When did this problem start?
Old 09-04-2011, 10:15 PM
bolivar
bolivar's Avatar
Mine had an occasionally gas smell the first couple of years. I haven't noticed it in the last couple.
Old 09-05-2011, 08:11 AM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
Are you still under warranty? If so, you paid for it, use it. If you can smell gas, you have a leak. Yes, on the C-5's, the crossover tube is a problem on some cars and yet others never seem to leak. This is the first I've heard of fuel odor on a C-6.
Old 09-05-2011, 09:22 AM
Dennis08
Dennis08's Avatar
The problem just started a few days ago, I've had the car for a year. I have stopped driving the car until I can get it to the dealer on Tuesday. The bumper to bumper warranty ran out two weeks ago. I still have the power train warranty left. I was hoping it would be something simple I could fix.
Old 09-05-2011, 11:13 AM
tampatopless
Support Corvetteforum!
tampatopless's Avatar
My son gets a gasoline smell in his rice burner and it's always the fuel filter, which has to be replaced regularly. We replace the filter and the smell goes away.
C5s have a lot of fuel smell issues but like the earlier poster, I haven't heard of that with the C6.
Old 09-05-2011, 11:18 AM
b4i4getit
b4i4getit's Avatar
Take your car to the dealer. If you smell gas that is not something that should be ignored.
Old 09-05-2011, 12:29 PM
dgrant3830
dgrant3830's Avatar
Try calling them right away in the morning and explain to them that this is a serious saftey issue and that your 3/36 just ran out two weeks ago. They/GM might step up and help you out on it or they might not. Either way, you have to get this fixed instantly.
Old 09-05-2011, 12:38 PM
Neil Baker
Neil Baker's Avatar
Are you over filling the tanks when fueling? If you are filling the tank by using the auto fill on the pump handle, never go past the amount when it clicks off, don't even round off numbers. Over filling the tanks can cause over flow and gas smell. Other than that, take it to the Dealership, it should be cover under the 5 year/100,000 miles, always ask first if it's covered.
Old 09-05-2011, 02:54 PM
Dennis08
Dennis08's Avatar
I never over fill the tank, when the pump kicks off I take the hose out. I will see the dealer tomorrow. I couldn't find anyone with the same problem with a C6. Thanks for the replys
Old 09-05-2011, 05:51 PM
keyplyr
keyplyr's Avatar
Default Gas smell
Pay extra for that?
Old 09-05-2011, 06:19 PM
laconiajack
On safety issues the warrantee never runs out, even though the "new" sleezebag GM seems to think so. Tell them to fix it at their expense immediately or suffer the consequences. If they don't respond favorably, lawyer up and go for the jugular!
Old 09-05-2011, 06:40 PM
Thrash
Thrash's Avatar
Could be my wife, was she riding with ya again?
Old 09-05-2011, 10:10 PM
Rebel 1
Rebel 1's Avatar
Good advice. Hope the OP has a GOOD dealer and will work with him on this issue.
Bob
Old 09-25-2011, 04:54 AM
CO Lightfoot
CO Lightfoot's Avatar
From another thread discussing a fuel odor:
Originally Posted by TTZ06VETTE
Check the EVAP canister vent hose up near the fuel neck to see if it came off. You may have to remove the inner rear fender to check this. If not it could be the top of the fuel pump sending unit where it attaches to the tank. They use neoprene washers that can eventually loosen or wear. This happened in my 2007 Z06 and it took me forever to find. No fuel leaking because it was on the top of the tank. The smell was terrible though in the garage or enclosed places especially after fill ups. Had to drop the tank to eventually find and repair.
http://forums.corvetteforum.com/c6-c...as-in-car.html
To Gas smell
Old 09-25-2011, 10:23 AM
dgrant3830
dgrant3830's Avatar
Yeah, I'm curious too as to the outcome on this.
Old 09-25-2011, 10:54 AM
pcguy2u
pcguy2u's Avatar
Old 09-25-2011, 11:12 AM
abstruse1
abstruse1's Avatar
I'm having a similar problem on my '09 Z06. Not very strong but still annoying (and sorta sickening) gasoline odor, mainly when driving around town with windows up and AC on. When I put the AC on recirculate, the odor goes away, as it does at highway speeds, and with the windows down at any speed.
So I assume it's coming in via the AC intake. Where is this -- at the base of the windshield on driver's side?
Car has had blower installed. No fuel pump work, but maybe some of the work under the hood involved fuel or evap emission lines.
Any suggestions?
Quick Reply: Gas smell
