Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-04-2011, 01:52 PM   #1
CitznFish
CF Senior Member
CitznFish's Avatar
Default Need to jack up my C6 to do a brake job
I've read multiple threads about using pucks, crossbeams, etc., and it all seems like overkill.
I have 4 jack stands and a low profile jack. Can I just use a cut 2x4 and the jack to lift the entire front and slide under my jack stands? Then do the same for the back end?
Or do I need to do one corner at a time?
I want to do this tonight and I don't want to spend $100+ on something I don't really need.
looking for real advice, not the safety crew telling me I need to spend an additional $200 before I can jack up my car.
Thanks,
CF
CitznFish is offline   Reply With Quote
Old 08-04-2011, 02:03 PM   #2
1988Bullitt
CF Senior Member
1988Bullitt's Avatar
I have a twin post at the house so whenever I need to pull off more then 1 wheel I just put it on that, however if I need to just pull off 1 wheel I will jack just that corner. I made pucks out of Delrin plastic for my jack and lift. I don’t see why a 2x4 wouldn’t work though. I have never jacked by the aluminum cross members I bet it’s pretty hard to get a jack all the way under the front one, especially with the air dam. Probably a lot easier to get to on the rear one, just be careful since they are aluminum. I would recommend going around to each corner and jacking on the factory lift points, knock that brake out then move onto the next one, one at a time that way you are safe and don't have to worry about damaging your car.
1988Bullitt is offline   Reply With Quote
Old 08-04-2011, 02:42 PM   #3
CitznFish
CF Senior Member
CitznFish's Avatar
Thanks for the input. Maybe I'll do just one wheel at a time. Was thinking it would be quicker if the car was up in stands itself. Maybe do an oil change at that time as well.
Wonder if I can lift one side, put it on stands, then lift the other side and put it on the remaining stands....
Old 08-04-2011, 02:48 PM   #4
StKnoWhere
StKnoWhere's Avatar
Your first proposal will work if your jack has enough reach. Lifting one side and then the other also. Two jacks make it even easier. The Vette is light so it doesn't take much of a jack.
A brake job can be done one wheel at a time.
An oil change can be done lifting the front drivers side.
StKnoWhere is offline   Reply With Quote
Old 08-04-2011, 02:55 PM   #5
carpe dm
CF Senior Member
carpe dm's Avatar
I use hockey pucks on my jack saddle and usually lift, and place jack stands, one side of the front at a time. I then use a 1x3x6 piece of oak on the jack, centered on the rear cross member, to lift the rear. Works great. You can lift the front, using this center lift, if you get the car up on "planks" so you can get the jack under. I would highly recommend getting a set (four or more) of used hockey pucks. I use them in the garage and take a set with us when we travel. I don't trust "Billie Bob" to lift my car without them.
carpe dm is offline   Reply With Quote
Old 08-04-2011, 03:00 PM   #6
Liner
CF Senior Member
Support Corvetteforum!
Did my brakes -- calipers, lines, pads -- this winter and jacked it up as you describe -- front and back.
However, I needed the pucks to place the jackstands. I guess I could have used the jackstands on the cross members, but that is where I was jacking from, so that's a problem. Plus, I wanted the stands out wider for stability.
You can certainly do one wheel at a time, but much easier if all four are up, especially if you need to bleed the system. JMHO
Liner is offline   Reply With Quote
Old 08-04-2011, 05:28 PM   #7
CitznFish
CF Senior Member
CitznFish's Avatar
found this..
Click the image to open in full size.
http://www.bugmanweb.com/c6/jack.html
So I'll try that route....
Old 01-04-2012, 08:30 PM   #8
grumpstar
Grumpy
jeffwilkinson2@aol.com
I need to remove my horizontal springs so I can put Coil over shocks on. And change the rotors to cross drilled. Any Ideas on jack for this application at home?
grumpstar is offline   Reply With Quote
Old 01-04-2012, 08:46 PM   #9
JoesC5
CF Senior Member
GM only recommends you lift the C6 at the four areas they show in the Owners manual. Those four areas do not include the frame rails or the center of the aluminum crossmembers.
http://www.chevrolet.com/assets/pdf/...12corvette.pdf Check pages 10-5 & 10-6.
Even though I have two 4-post lifts, when I want to remove the wheels to really detail the wheel wells I do it in my driveway so I don't make a mess in the garage.
I have a pair of ramps that I made(required in order for me to get a jack under the front of my Z06) that I made from 2X12's stacked two high(3" of lift). I run the car up on the ramps and then I have a spreader bar I made from a 2X6 with 1/4" thick plywood pads(5.5" X 5.5") on the ends. The pads match the two points on the aluminum crossmember where GM says to jack the car. I then use my floor jack and raise the car, then I put the jack stands under the ends of the spreader bar. Removing the wheels is then a breeze.
JoesC5 is online now   Reply With Quote
Old 01-04-2012, 08:48 PM   #10
Kiser64
CF Senior Member
St. Jude Donor '12
Kiser64's Avatar
There is a guy on here, funvette-1nc, I think, who is doing a front wide body, after his fell off a jack doing the brakes. I have been reticent to jack mine, it just seems unstable on 4 stands at the crossbeams to me. To the point that i'm looking for a good scissor lift...That being said, a bunch on guys on here use the crossbeams and rocker jack points with no issues. Do a search for lifting, there is plenty...
Take your time and be careful, good luck!
Kiser64 is offline   Reply With Quote
Old 01-04-2012, 08:57 PM   #11
JoesC5
CF Senior Member
I only do my car one end at a time. That way I have at least one end of the car where the rubber is on the ground.
Old 01-04-2012, 10:05 PM   #12
TJay74
CF Senior Member
TJay74's Avatar
What about drive up ramps, are they worth it?
This is the first car I have owned that sits this low and I like others am very skilled in the garage, but dont want to take a chance and mess up something by accident.
TJay74 is offline   Reply With Quote
Old 01-04-2012, 11:29 PM   #13
Fred@ReverseLogic
Supporting Vendor
Fred@ReverseLogic's Avatar
Race Ramps are not inexpensive. But most forum members who have purchased them agree that the ramps are safe and convenient to use, easy to handle, and worth the price.
We offer custom two-stage incline Race Ramps that get excellent customer reviews on this forum. We currently have some special priced bundles for the two-stage incline ramps, accessory ramps and wheel cribs.
http://www.reverselogic.us/specials.html
__________________
www.ReverseLogic.us
Fred@ReverseLogic is online now   Reply With Quote
Old 01-05-2012, 12:03 AM   #14
Dendk
CF Senior Member
Dendk's Avatar
Also food for thought...if you are going to remove the rotors for any reason...the caliper mounting bolts you need to remove can be a pain unless you have it on a lift.
Dendk is offline   Reply With Quote
Old 01-05-2012, 12:21 AM   #15
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '11
Racer's Avatar
I have owned a ton of C5's and C6's. Have done at least 7 complete rotor and pad changes, last summer was the first time I have used hockey pucks, only because I don't want to wreck my side skirts on my ZR1. Just jack it up on those lift points and put stands under those recommended places shown above and you will be fine.
Racer is offline   Reply With Quote
Old 01-05-2012, 11:18 AM   #16
speedraider
CF Senior Member
speedraider's Avatar
Its just a car, anyone with a half of a brain can use just a jack and throw a stand under the a-arn. One wheel at a time. People that are scared not using pucks shouldn't work on a car.
speedraider is offline   Reply With Quote
Old 01-05-2012, 12:08 PM   #17
427Z0SX
CF Senior Member
427Z0SX's Avatar
I drive up on these home-made wooden ramps, then jack up the rear under the crossmember (with a 2x4 on top of the jack), and put the plastic ramps under the rear wheels. If I was to do a brake job, I would just raise up one end of the car at a time, and use jackstands.
427Z0SX is offline   Reply With Quote
Old 01-05-2012, 12:57 PM   #18
grumpstar
Grumpy
With all due respect, just because I'm asking questions does not make me stupid, or unable to work on my car. Did you just wake up one morning and know everything, I know I didn't.
Old 01-05-2012, 01:00 PM   #19
grumpstar
Grumpy
Thanks guy, this is a big help. I've been a contractor for 40 years. I can make these, Thanks
Old 01-05-2012, 01:19 PM   #20
EDinPA
CF Senior Member
EDinPA's Avatar
Quote:
You should do a search for 'cracked rockers'. You could learn about all of the ignorant people that damaged 'just another car' because they did not know better. Many of them being well paid and supposedly trained dealer technicians.
People too obtuse to recognize their own ignorance should not work on cars.
EDinPA is offline   Reply With Quote
Reload this Page Need to jack up my C6 to do a brake job
Tags
2005, 6c6, brake, c6, corner, corvette, corvetteforum, forum, jack, jacked, jacking, job, lift, newer, ti, time, vette, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
