Those of you with F55 suspension.......
How much time do you spend in Sport or Tour mode. I spend probably 95% of the time in Tour. The only time I use Sport is on twisty roads or on hard acceleration from a stop to minimize wheel hop. Just wondering how others use this feature.
Same here; 95% of the time in the Tour mode in order to keep all four wheels planted all the time, plus to enhance Active Handling contribution.
Having this option since 2000 I'd say 50-50. I like the more responsive feel I get on the curvey roads I get to drive as I drive to work. Really depends on the road I'm on thou and living in MN that's hard as roads up here are not that great. Fortunately, the roads I drive on are fairly smooth.
One of my most enjoyable drives is up 94 west to my lake place in Alexandria for sure.
Somba master
I switch to tour mode when driving on bad roads or those stretches with expansion strips that are irritating. Makes a big difference. That is the real test of how the F55 works.
You probably have smooth roads! Try this, take it up to about 50 mph and do some little side to side zigzags . . . short and quick, switch modes and do it all over again. Bet you'll notice a difference then.
sport
Most of the time I'm in sport. I like to drive the car thur the twisted NC roads . My car has an A&A supercharger kit making 574HP to rear tires with an A4 auto trams. Also my car has a rear widebody kit and Z06 sways front and rear. 19x10 front and 20x13 IFORGED rims. Baer 14/14 rotors and 6 piston calipers brake kit on the way.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
Tour mode most of the time, but I do flip the switch to Sport all the time (cloverleaf onramps, twisty roads, etc.).
I DD an A6 and the trans is typically on S. I paddle shift all the time, but it's typically 1st, 2nd, and then hold the plus (+) paddle and the transmission will switch back to auto for cruising. I kinda use the F55 switch the same way. I'll see an upcoming situation where I'd like to tighten up the car, and I'll reach down and turn the switch to the right. Then once back going straight, flip the switch back. It's an automatic reaction now, just like shifting, I don't always consciously think about it.
Every now and then some expansion joints do remind me that I've left it in Sport.
I'd estimate that I stay in sport mode 95% of the time. As soon as the road clears up, I go out of tour mode. I like the ride in sport mode much better when you get into any higher speed turns.
