QA1 Coilovers?
#61
UPDATE FEB 22, 2012
Sorry for the long delay. I got my car back from the body shop for the rear end collision that happened in Dec. I haven't installed the revised QA1 coilovers yet, but here are some pix and observations.
QA1 added a spherical bearing where the rubber bushing used to be. My concern here is a much harsher ride vs the more compliant rubber bushings. I totally felt the difference when QA1 sent me the poly bushings that they had me try to remedy the noise. It will be interesting to see how these SOLID sperical bearing do for ride comfort:
QA1 clearanced the lower spring perch ID to add more clearance between it and the shock body. Hopefully no more scrapped up shock body:
Depending on my schedule, I will hopefully be installing these in the next couple of days.
#62
CF Senior Member
I've never heard of QA1 coil-overs either. I use LGM coil-overs and I've never had any noises or issues. Can you isolate which corner the noise is coming from? If so I suggest you remove the assembly and inspect it thoroughly. Good luck.
#63
Wayne- did you, by chance, read this from the beginning to end? This thread has been an on going saga. Hopefully I'm at the tail end of it
#65
It's good to see them making some pretty big changes based on your (and perhaps others) experience. It has taken a while but it looks like they followed through. Hopefully problems solved.
#66
I'm just worried about the ride of the solid spherical bearing that is replacing the rubber (soft riding) bushings...
Remember, I daily drive my Vette and it used to have a F55 suspension, so I'm accustom to a "soft" ride. I totally felt the difference between the rubber and poly bushings.. way more harsh. I'm affraid that fixing the angle problems with the sperical bearing will just open up comfort issue for me...
#68
We will see..
I'm just worried about the ride of the solid sperical bearing that is replacing the rubber (soft riding) bushings...
I have Bilstein Sports and changed out the Bilstein top bushings to solid Pfadt Delrin Spherical Pin Top mount. I felt no difference in comfort in terms of harshness, but I do feel the suspension is freed up. I changed to the Pfadt mounts to relief the shock piston side loading as well as inhabits free articulation due to the rubber mounts.
In my case, the Pfadt Delrin Sphericals provided the free articulation, enabling the shocks to perform their designed functions to smooth out road irregularities. The Pfadt Delrin Spherical Pin Top mounts although solid, unlike solid engine or transmission mounts, it is part of the shock assembly, thus generated no adverse effect in terms of DD comfort. As a matter of my seat of the pants, in place of the previous delayed, sluggish rubbery effect, now, cushioning is direct/crisp and more comfortable.
IMO, the spherical and clearanceing of the spring mount is a move by QA in the right direction, given the previous problems with spring rubbing the body, poor angle top mount and the binding issues.
I hope that works out for you, your trial will surely benefit those want to use as well as the company making the coil overs.
#69
#71
02.24.2012 UPDATE
I took a break from work today and installed the updated rear coilovers.
I only went around the block after installation and did some hard left to right and right to left weaving turns. I did hear a slight noise, which I suspect is the upper shock mount twisting and hitting the mounting bracket under this hard load. There was NO CLUNKING!
I will do some driving this weekend and give an update after I put some miles on them. My first impressions is that these fixes have cured the original issues that I had
More to come after I do some driving
#74
Sorry All... I wanted to do some more miles on these, but here's a quick update.
Noise all went away. The spherical bearing did the trick for the noise issue. I recommended to QA1 to put some kind of stop on the bearing so that the upper shock mounting eyelet doesn't rotate and hit the upper mounting bracket during suspension travel.
Am I happy with these shocks... Yes and No....
I'm happy that I can lower the car and still get full suspension travel.
I'm not happy that I have to set the rear shocks at setting 8 in order to keep the rear end from pogo-ing when hitting a dip or expansion joint at freeway speeds. It's bad enough to lift my rear from the seat when set at 7 or lower. I still get some pogo-ing at 8, but just haven't had the chance to click it over to setting 9 to verify it will go away. I was hoping that the spherical bearing would fix this as I had read that the binding could cause a pogo-ing effect. Setting 3-5 is much like my F55 suspension, setting 8 is very much like a z51 setting.
I purchased this car specifically because it had a cush ride, now since I have to have the shock setting at a stiffer setting, I'm not a very happy camper. QA1s response to the pogo-ing was to "purchase" a set of double adjustable shocks from them... NOT... after all my troubles, you would think they would at least investigate this issue on their end. Their response to me was that they have never heard of any complaints about pogo-ing with their set up. I haven't had time to find the threads where others have complained about this effect on their shocks so that I could forward them to QA1.
My recommendation is that if you don't mind a harsh Z51/Z06 type ride, then these are a great lower price alternative to other coil overs. For street driving on perfect roads, these shocks handle awesome.
I daily drive my car, and I'm afraid that upping the setting to 9 to get rid of the pogo effect my make my commute not so friendly. I may end up selling these LOW mileage coil overs and purchase another brand in a double adjustable set up...
#75
Will work for HPDE time.
#76
They do handle WAY better than the compressed (from being lowered) F55 shocks that they replaced..
#77
Yes, it's a vast improvement. I would say that these are worth the money, if you don't mind a Z51/Z06 type ride. I was truly hoping to keep the ride comfort that I originally had with my F55 and be able to lower the car.
Now even one forum vender is carrying the QA1 line!
I am very hesitant, wouldn't mind spending more on the proven design for the long haul!
Nice rear by the way, especially your rears come correctly painted IIRC?
#78
I track the car 4-5 times a year, so getting around a road course is the primary concern for me. My home track is very bumpy, however, so the "pogoing" you speak of worries me.
#80
I have the 450 springs in the front and the 550 springs in the rear
