Replace Clutch Fluid - Modified Ranger Method
It took awhile, but I modified the way I swop out my clutch fluid.
Got a couple 40 cc medical syringes with some large needles. One for sucking out bad fluid, the other for filling with clean fluid. Went on the WEB and found some thin black nylon tubing. Stiff walls, but flexible. Dimensions are 0.075 ID and 0.125 OD. Cut it about 18" long.
Process. Suck out the bad fluid from reservoir. Fill syringe with clean fluid. Install long tube. Push out the air. Insert tube down into the clutch line thru hole at the bottom of the reservoir. Squeeze in the fresh fluid. It pushes the dirty stuff out of the line up into the reservoir. Suck out the reservoir again. Fill reservoir to full mark. Done.
Can't believe how much junk this pushed up and out of the line. No more pumping trying to clean out the clutch line.
Easy, peezy, quick and easy.
VFR RC46 (05-03-2019)
Wow, sounds like a good idea.
But for my feeble mind I need pics..
You could have a sticky!
Maybe you should start offering kits...
Ranger, you are the original hydraulic clutch guru, does this get your stamp of approval?
Considering that the black material is dust from clutch wear and has worked its way up from the slave cylinder, what we see in the reservoir is just the tip of the iceberg. The real nasty stuff is between the slave and master cylinders. Unfortunately, it's not easy to flush that fluid without buying and extender for the bleeder valve.
... And the extenders have been known to leak.
Search for these:
Black Nylon 12 Semi-Rigid Tubing, 0.075" ID, 0.125" OD, 0.025" Wall, 10' Length
Medline DYND20325H Syringe,Piston,Irrigation,60Ml,Steril - 1 EA
Try using about 2-3 paper towels. Stuff them in the reservoir, absorb all the old gunk, refill with fresh fluid. Call it the "Cheapskate" method.
I apologize for not doing a tutorial with pics.
Thanks. Ordered the tubing from amazon using prime for shipping. Ordered the syringe from "HealthCare Supply Pros" all from google search
I found an automotive syringe at an auto parts store. Came with some tubing, but I don't use it, just insert the syringe into the reservoir and extract all the fluid in one draw.
Sounds like a real improvement in "process" that will make the job easier and get more gunk out.
I continue to be dismayed and disappointed in the factory for:
1/ This design flaw in the first place.
2/ Not fixing this design flaw once it became known.
All I can say is, the first time I did it with the thin tube, I was amazed at how much junk came out. This was after having it cleaned previously the way you have listed.
To each his own.........
Location: Stafford VA, home of our wolf den. No house break ins to date.
Yours is how I did it before. The issue is, the feedline down to the master cylinder from the reservoir still contains junked up fluid. By using the thin tubing, you can inject the fluid down by the master cylinder at the bottom of the hose, and push all the junked up fluid up and out into the reservoir. This is about all you can do to clean out the system short of doing a real line bleed of the system, which from what I understand, is a real PITA.
ive used RAngers method twice now and my fluid is staying pretty clear.. but the crap "down under" concerns me.
I agree, with regular "Ranger method changes", my fluid stays clean.
Not sure was is underneath so to speak.
Also I am still not sure where the rubber tube gets attached? So I can find out what is below...
What gauge needle did you use, 16 or 14?
Thanks for sharing your system so far.
bstedman (09-06-2021)
Here is my latest design that seems to work best for me. I replaced the needles with some tubing as it allows for better flow.
These are 60CC Syringes.
The one on the left is used to remove (suck out) bad material from the clutch reservoir. I stuck a small piece of small engine gas line into it to extend the end.
The one on the right is used to inject new fluid. I found access to some tubing that has connections that screw directly into the syringe. The short piece I use to extract good fluid from the Dot 4 Brake fluid container. Once I fill the syringe with new fluid, I change tubes to the black tube. I invert the syringe and pump material to remove air. I insert the long black tube down into the reservoir feed tube at the bottom of the clutch reservoir (small hole at the bottom). Once I insert it all the way in, I inject the good material in, it then pushes the bad fluid up into the reservoir, thus cleaning out the fluid line. I then remove the material from the reservoir, and refill with good fluid. If you can't find the tubing that screws into the syringe (medical supply), then you can try the small engine gas line.
Again, the intent is to remove as much as possible all of the clutch fluid. This basically eliminates the pumping one needs to do with Rangers original method, and for me, does a better job of changing out the fluid. The only way to better change the fluid is to have the system bled.
Steps:
1) Use syringe to suck out fluid from reservoir (just like the ranger method)
2) Fill second syringe with new fluid.
3) Install long black tube on syringe that is filled with new fluid.
4) Invert syringe and squeeze some fluid out to purge out air from the black tubing (just like the nurse before she/he jabs ya).
5) Insert long black tube down the hole located in the bottom of the reservoir
6) Inject new fluid into clutch fluid feedline. Old fluid gets pumped up into reservior.
7) Pull out the syringe and black tube.
8) Use the removal syringe to suck the bad fluid from reservoir that used to be down in the feedline.
9) Fill reservoir with fresh fluid to fill mark.
10) Clean-up
