Now instock! Arc Audio XDI Mini amps! hide them anywhere(pics)
Former Vendor
I just got in an order of ARC Audio products and thought I would share with you guys the size of the new XDI series mini amps
These bad boys are tiny! I have the 4 channel and 5 channel that I took some pics of to show you how small these amps are These days so when your thinking of upgrading the system in your car you dont need to WOrry about a big bulky amp and where your going to put it.
These will easily fit behind the passenger seat or even mount in the rear well of the car as well.
The first one in the pics below is the XDi804 4 channel amp
specs on the 4 channel
Power Output
120 x 4 @ 2 ohms Stereo
Power Output
240 x 2 Watts @ 4 ohms bridged
Bass Boost
+15dB @ 45Hz
Remote Bass Boost
Yes
Fusing
2 x 25 Amps
Power Output
80 x 4 Watts @ 4 ohms Stereo
Crossover (Butterworth)
HP/LP (50Hz - 250Hz)
The second pic is the XDi805 5 channel amp
specs on the 5 channel
Power Output
Channel 1 - 4 80 x 4 Watts @ 4 ohms Stereo
Power Output
Channel 1 - 4 120 x4 Watts @ 2ohms Stereo
Power Output
Channel 5 - 240 x 1 Watts @ 4ohms
Bass Boost
15dB @45 Hz
HP (50Hz - 250Hz) / LP (50Hz - 250Hz)
Remote Bass Boost
Yes
Fuse
Yes
Power Output
Channel 1 - 4 240 x 2 Watts (Bridged) @ 4 ohms
Power Output
Channel 5 400 x 1 Watts @ 2 ohms
As always for best pricing on ARC and many other audio products send me a PM or email.
We are limited to MAP pricing on these for everyone to advertise
Power Output
Power Output
Bass Boost
+15dB @ 45Hz
Remote Bass Boost
Yes
Fusing
2 x 25 Amps
Power Output
Power Output
Power Output
Power Output
Bass Boost
15dB @45 Hz
Remote Bass Boost
Yes
Fuse
Yes
Power Output
Power Output
