Corvettemods HID Fog Light Kit Installed
Former Vendor
St. Jude Donor '12-'13
Got mine in only 3 days from order to door. Installed them last weekend, which took about 30-45 minutes start to finish (most of that was me being OCD due to it being my first time jacking up the car). Easy mod, and they look absolutely awesome. Perfect match to the stock headlights.
1 Post
I installed these a couple of weeks ago. They look great and were really easy to install. By the way, I did not have to remove the tire. I had plenty of room just by turning the wheel, removing the torx screws on the fender liner, and pop one push pin out.
You do not need to take the wheels off to do this...remove the push pin connectors on the front of the wheel well....remove two 7mm screws underneath and remove screws from that part of the valance...also 7mm, and take that wheel well piece out...it will slide right out without removing the wheel....then you have full access to both fogs and driving lights up top....if you feel you need more room....turn the wheel so the tire is facing in......Hope this helps.....now get her done!!
Former Vendor
Received 1,506 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Can you supply me with installation instructions?
Thanks!
Thanks!
#34
Great Mod.
I found I could turn the left wheel enough to gain acess. The right (passenger) wheel had to be removed. Boy oh boy, what a difference. This is the way it should have come from the factory. Other than my Z06 exhaust this is probably the best mod I have done.
#40
Lots of responses but nobody said how well they illuminate!
So how about it? Do they mainly shine close up, to augment the low beams, or do they act like a long distance driving light?
