Car acting weird... "TOP NOT SECURE " and trunk not opening
Old 06-18-2011, 05:26 AM
stevette17
stevette17's Avatar
Default Car acting weird... "TOP NOT SECURE " and trunk not opening
On break went to get a coffee its saying TOP NOT SECURE (unlatched and re latched top still same)
When i left work i opened trunk to put my stuff in closed it. Realized i forgot to put something in and then trunk wouldn't open from fob and inside car. Got TOP NOT SECURE message again. Drove home put gas still nothing. Opened it with key and closed it tried again nothing. after getting gas TOP NOT SECURE message didn't come back.
I got home parked it shut it off and now trunk opens???
Old 06-18-2011, 08:03 AM
Corpsvette
Corpsvette's Avatar
Really reaching here but I'm gonna go with it being something related to the battery.
Old 06-18-2011, 10:10 AM
SilverScorp
SilverScorp's Avatar
I never knew the DIC had a 'top not secure' message, that's a new one for me.
Old 06-18-2011, 10:19 AM
akriggm
akriggm's Avatar
You may want to check the top protector panel in the trunk - one of the rings on the ends of the panel may have loosened when you put the first load of stuff in the trunk - they can be finickey......
Enjoy,
akriggm
Old 06-18-2011, 11:24 AM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Along with the partition the sensor on the windshield header may be getting dirty or corroded or could be early signs that one of the other six sensors may be going out.
Could just be a momentary glitch too.
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old 06-18-2011, 11:28 AM
SolidlyStated
SolidlyStated's Avatar
C7 of Year Finalist (stock) 2019
Wow did not know that it had sensors for that. That feature would have saved me a t-top in my 2001 trans am. That Mustang always thought he won that street race, but I was pulling over because my top flew away.
Old 06-18-2011, 12:39 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
It's only on convertibles.
Old 06-18-2011, 12:48 PM
6spdC6
6spdC6's Avatar
Location: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I had the same problem with my 05 Vert, it was a ''something'' that had shiftef just a bit and would not make a good contact. One safety sensor out just a touch and this is what happens.
Old 06-18-2011, 12:57 PM
cclive
cclive's Avatar
There is a small limit switch in the hole where the top piece fits on top of the windshield on the passenger side. If the top piece is not down in this hole, that message is displayed. That switch is not working properly. If the top is not either all the way up or all the way down, the system will not allow opening of the trunk. Get in there and check that switch, maybe a bit of contact cleaner.
CORRECTION, the limit switch is on the driver's side...with a small screwdriver, you can push it and hear it clicking when it connects....
mg1964 (09-28-2016)
Old 06-18-2011, 04:41 PM
tomzarbo
tomzarbo's Avatar
I agree with this diagnosis.
The convertible lid and trunk cannot be allowed to open at the same time because of interference, (they would hit) and if the sensor indicates that the top is not secured at the windshield, that part may be tied in with the convertible lid somehow sensor-wise.
Old 06-18-2011, 07:25 PM
stevette17
stevette17's Avatar
I looked at the switches/holes only the driver side seems to have a tab in it when lookin in directly the hole from top...??
Old 06-18-2011, 10:05 PM
cclive
cclive's Avatar
Yup, that tab is the limit switch. Use a small screwdriver to push it in and see if you can hear it click....that switch will cause the DIC message if it is not working right..
Old 06-19-2011, 02:52 AM
cranky
cranky's Avatar
when my 05 vert did this, the 5th bow sensor was shot............ diagnosed with a tech2 that could read the BCM. had to be replaced. no problems now, for three years...........
Old 06-19-2011, 02:57 AM
stevette17
stevette17's Avatar
The odd part is u guys said it was on pass side mine is on driver side.
Where r all the sensors located?
I ll have to wait till the dic msg comes up again
Old 06-19-2011, 07:32 AM
Bluewasp
Bluewasp's Avatar
NoVa Events Coordinator
St. Jude Donor '14
Lulz, Top not secure is on the verts.
Old 06-19-2011, 12:19 PM
cclive
cclive's Avatar
The limit switch is indeed on the drivers side.....my mistake which I corrected in my previous post yesterday.
Old 06-21-2011, 12:01 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
Dear stevette17,
I apologize for the time frame of my response to your situation. Since the 19th of this month, what have you found with your situation? Have you talked with the service technicians about this?
Sincerely,
Michelle, Chevrolet Customer Service (assisting Laura)
To Car acting weird... "TOP NOT SECURE " and trunk not opening
Old 07-01-2011, 02:19 AM
stevette17
stevette17's Avatar
I found the one in the trunk for the top protector. So where are the rest of the sensors located and how many is there ? I tried the one on the drive side winshield with the top not secure msg on the dic - when I push it it clicks and makes the dic beep but message does not go away. Where can I get a cheap tech 2 from? Thx
Old 07-04-2013, 08:53 PM
dlgolder2
Cruising
dlgolder2's Avatar
Default top not secure
I need instructions on how to get the contacts for the convertible top contact out of the windshield frame. Any help?
Old 07-04-2013, 09:23 PM
vettman96
vettman96's Avatar
Agreed, sounds like batt voltage may be the root cause.
Quick Reply: Car acting weird... "TOP NOT SECURE " and trunk not opening
