$50 dollars to remove road noise/exhaust drone :)
#101
Actually it's a killer even with GM OEM exhaust. I added the NPP exhaust a couple of years ago, no drone with the valves closed. I recently added the ARH long tube headers with hi-flow cats and now I can't get rid of the drone even with the valves closed. As you mentioned, 1600 rpm is the worst and I have to be below 62 mph or above 75 mph to get rid of it.
Autos (A6) are tough because of their gearing, 256 rear. I'm hoping your solution works as you mentioned it reduced the drone but you have not stated that it eliminated it and I'm looking for total elimination. Correct me if I'm wrong. Anyway, great writeup and info. Thanks.
#103
#104
Next time you are driving say 30 miles reach under your back carpet and feel the P&S tape. That stuff is so hot it will almost burn your hand. I can not believe how hot that floor gets. I did notice a slight Tar smell when i got in the car after it sat in 100+ degree heat all day. It was not bad and went away the second I started the car. No I did not use foil tape over the P&S because I want to add one more roll. The foil tape takes care of any Tar smell correct?
#105
Did you overlap the peel and seal? I didn't use any tape either but haven't had a smell at all. People who did said the tape sealed it all in though.
#106
Mine is definitely not eliminated at this point. It GREATLY reduced drone at 1500 rpms and 1700rpms (estimates based on the tach) but at 1600rpms there is still very noticeable drone with my setup, which is why I'm going back in to cover a bit more like Presidentialpawn did. 1600 is better now, but I've still got some work to do
I am planning on ARH adding resonators which they say will eliminate the drone. I still plan on duplicating your process to eliminate any residual drone, if any, and to reduce road noise.
#107
Ok, here's an update.
1 roll weighs exactly 3 pounds and 8.7 ounces. I unrolled it and took out the middle cardboard piece so it would be precise. After 5 rolls I haven't even quite added 20 pounds
[IMG][/IMG]
1 roll is JUST enough to do two layers behind the front seats. The carpeting behind the front seats just pulls out. It takes less than a minute to get it out and about 5 minutes to get it back in.
After 1 week of 100 degree days in Houston there is no sign of melting in the back. The rear is warm to the touch under the carpet, but I had no problem holding my hand to it and jumping into the back on my knees working for 30 minutes laying down another roll. This was after being out driving for about 1 hour with the weather showing 95 degrees. When I pulled the carpet up there was also no hint of tar. I think the key is really getting the edges to smash down and overlapping when you lay it. I suggest using a paper towel to smash it all down so you don't cut your fingers up.
[IMG][/IMG]
#109
No, you don't need to remove the seats, just push them forward and you have all the room in the world.
In that picture the seats are still in, but there's TONS of room. They weren't even pushed up all the way
#110
Just got back from a drive around the neighborhood and down the street.
I believe I'm totally satisfied now.
I kept it in 4th gear to hit 1500, 1600 and 1700 rpms and the drone is all but dead. You have to understand that the exhaust is still quite loud, but the drone is what sounded terrible, and I've basically killed it. It'll never be 100% with my setup, but if it was a Catted X-pipe I bet it would be REAL close.
4 rolls in the back and 1 roll behind the seats seems to be the ticket. In the back the focus was around the center 3x3 area. Wheel wells got 1 layer, all of the rear floor got 2 layers, and the center 3x3 portion got 3 layers.
Good luck all!
Tomorrow is a ~200 mile trip to Austin for a wedding, so I'll report back what the wife thinks about it.
Good luck all!
#111
#112
[IMG][/IMG]
[IMG][/IMG]
I did not overlap mine and I did not get all the edges down 100% perfect. When I get my car back and put down the second layer I will make it right.
#113
I think that's probably why you're getting a smell.
I wouldn't lie to you guys. I have absolutely NO smell in my car and I think it's due to care in installation.
#115
Marking the holes for drilling.[IMG][/IMG]
My buddy Chad from Midas with the cross pipe welded in.[IMG][/IMG]
[IMG]The mid pipe mounted in. Sorry for the black paint.[/IMG]
The above shows you the location of the cross pipe. You can use any diameter pipe. Make sure the exhaust is only drilled with a 1/2 inch bit, don't make any huge holes in the main pipes. What you are doing is creating a resonating chamber for both sides without restricting the exhaust. My car had become very quiet after adding the Peel&Seal and welding in the cross resonating chamber. What had happened in reality- some of the annoying low frequencies were killed by the addition of the pipe.
#116
I have done some research on sound deadening and in particular resonance. What I found is that you don't need to cover everything with sound deadening material. The trick is to find the panels that go into resonance by rapping on them with your knuckles. The ones that resonate are the offending areas. You only need to put a patch about 1/3 the size of the panel in the center of the panel. You should use a good quality material like Dynamat because it has weight and a visco-elastic material. You need the weight and the visco elastic material to dampen and change the frequency of the offending panels. The weight is important so lighter isn't necessarily better. However, because you aren't covering the entire panel the total weight isn't too bad.
Resonance can also be transferred into the car structure through the exhaust hangers. You can try adding a little weight to a longest length of the exhaust pipe to see if that changes the frequency.
Hope this helps.
Hope this helps.
#118
How is the peel and seal holding up attached to the floorboards on the outside of the car? How long has it been since you did the install? Any separation issues?
Thanks for the pictures.... Looks good!
#119
Hope this helps.
Hope this helps.
This is a cheaper, effective alternative.
#120
If you misplace it on a flat surface it takes a long time to remove. It is almost impossible to peel this stuff off . I think I bought the car in January 2011. No melting even in the engine compartment. Don't put it on the exhaust- too hot it will melt.
