How Do You Remove Center Caps W/O Scratching
Old 05-27-2011, 02:57 PM
Jaws12
Jaws12's Avatar
Default How Do You Remove Center Caps W/O Scratching
Mine are in tight and I just realized the point isn't aiming towards the valve stem.
I can't seem to pop them out.
Thanks.
Old 05-27-2011, 03:03 PM
IDSRVIT
IDSRVIT's Avatar
Thanks.
Did I miss a golden rule somewhere or is this a case of personal OCD?
Old 05-27-2011, 03:27 PM
MARSC6
MARSC6's Avatar
Take the wheel off and push through the hub.
Old 05-27-2011, 03:29 PM
jackcasa
Support Corvetteforum!
jackcasa's Avatar
Actually, it dates back to the C1s and NCRS judging standards for that "generation."
WV Vette
WV Vette's Avatar
Yep, I changed mine and you have to remove the wheel and push them out from inside the hub.
Old 05-27-2011, 03:31 PM
SRQStingray
SRQStingray's Avatar
I use a little suction cup that came with a thing for changing out lightbulbs that are too high to reach. Works great.
Old 05-27-2011, 03:37 PM
IDSRVIT
IDSRVIT's Avatar
Very cool.... I did not know that. There you go..... I can stop today since I learned my one thing for the day.
Old 05-27-2011, 03:45 PM
jackcasa
jackcasa's Avatar
I use a special suction cup "tool" that I bought to remove the center caps on my '65's KO (knock-off) wheels. Works great on the C6 as well.
Old 05-27-2011, 03:47 PM
jackcasa
jackcasa's Avatar
"Trivia is everywhere rampant" on the CF.
To How Do You Remove Center Caps W/O Scratching
Quick Reply: How Do You Remove Center Caps W/O Scratching
