Issue AFTER Issue AFTER Issue...
Ok so far I submitted my car for the traction control light and the roof recall. During that extravaganze, I noticed that my car had a new jingling sound which turned out to be a bad lifter!!!
Then my warranty gave me a new cam! After they had finished the installation of the cam shaft, they noticed a small coolant leak next to my water pump. Lo and behold! a new water pump for me....
Now I bring the car back and I notice a slight squeak with the clutch pedal, it almost seems like there is a bubble or even bad clutch fluid in the system, gears engage fine without difficulty, but when I depress the clutch pedal, I hear an ever so slight squeak from behind my clutch cylinder just behind the firewall behind the clutch cylinder. I went as far as taking apart the inside area near the floor amt and have successfully lubed up everything! It seems like flushing the clutch fluid will be a real PITA!
So I am using the turkey baster clutch fluid replacement method for that.
TODAY, as I was focused on my clutch pedal and pumping away as I usually do, all of a sudden my gas gauge goes from 1/4 tank to immediately 0! I get the Service Fuel System light and my "range reads low" but the car runs fine...
I took the car to a gas station and filled it up with more gas and lo and behold, no more gas gauge problem. Everything runs fine (with the exception of my clutch pedal)
If there is someone who may have a better idea behind my clutch pedal issue I would be more than willing to listen.
I feel like every few weeks there is some new issue with this car.
It is a 2005 C6 Z51 with 85,000 miles...
So far my warranty has replaced:
BOTH CATALYTIC CONVERTERS
THE NAV UNIT
RADIATOR
Column Lock
Thank (whoever your diety is) for WARRANTIES!
THE NAV UNIT
RADIATOR
Column Lock
BTW, when you have a car with 85,000 miles, **** happens. Things wear out and some cars have more problems than others. That said, at least you have a warranty! Good luck in the future.
I had the gas gauge issue when I purchased my car. When the tank was filled up the gas gauge would move to the Full mark but it looked like it was sticking, then it would go to empty and display the service fuel system message. After using about an 1/8 of a tank it would work fine. I filled it up 3 times with Chevron and the problem went away and hasn't come back.
A squeak...do you have any mouse droppings near the pedal?
On the gas gauge..dump in a 20 oz bottle of Techtron in the gas tank. I do this every 3-4,000 miles. Walmart carries it and Pep Boys has sales on Techtron ever so often.
THE NAV UNIT
RADIATOR
Column Lock
THE NAV UNIT
RADIATOR
Column Lock
By the way my warranty lists is twice as long as yours!
Brake pads
A/C
clutch spring and master
DRL wiring harnesses
Rocking seat fixed
Harmonic balancer fix
DBS reflash done
Buzzing shifter fixed
2 roof fixes.
squeak is likely the return spring. my '08 had same noise but after a lot of lube, it went away and hasn't come back.
as for the gas gauge, try running Chevron gas for a while or add a bottle of Techtron to the gas for the next 2-3 fill ups. seems to help resolve corrosion issues and sending unit problems. you can get the additive at GM dealers or just run Chevron fuel. plenty of those stations in Houston.
good luck
good luck
CF Senior Member
I don't necessarily subscribe to that adage. Years ago (after hearing this sentiment often) I did a poll of 2005 C6 owners. Well over 90% considered their 2005 C6 to be reliable and they were very satisfied with the car. Improvements are always ongoing. There are 'problem prone' cars from all model years. I literally wail on my (modified) 2005 and its been extremely reliable and trouble-free. If I would have waited for the 2006 model year I would have got a Z06 but forget that....I would have deprived myself of one year of enjoying my wonderful C6!
No Excuses
My 2005 has also had a list of problems. It's a Chevy thing. As much as I like the model, it lacks quality. We have a 2003 Honda van we purchased new that now has 110,000 miles. The only problem is a rear power window motor that went out. Guess what? My wife wants another Honda. Not a chevy traverse, tahoe, or similar model. Quality and trouble free ownership retains customers. The sooner GM learns this the sooner their shares will go up in value.
How long have you been doing the Ranger turkey baster clutch fluid method? Do you think that might have contributed to the clutch issues? Ive considered doing it but have heard pros and cons.
Well the turkey baster method for about 2 weeks. The squeak was very prominent uyesterday. For some reason I don't even see a clutch spring, I can see where the hinges are and wher it is supposed to sit, but no spring. Weird.
I would like to also know what exactly is the rattling gear... I heard mine go crazy yesterday!
I even went as far as pulling the wheel well out from the drivers side off to investigate and there seems to merely be the clutch pedal piston with very small tubing that traverses the firewall and heads towards the clutch assembly... I didn't see any leaks, but the entire module feels a bit loose??? is this normal?
1 Post
St. Jude Donor '06-'07-'08
