Rev Matching
Old 05-15-2011, 02:12 PM
RolexnVettes
5th Gear
RolexnVettes's Avatar
Default Rev Matching
How many of you manual Corvette owners rev match (either single clutching or heel toeing) when you downshift? I'm not talking about racing either, just casual Sunday driving.
RolexnVettes is offline
Old 05-15-2011, 02:14 PM
smurfkiller
smurfkiller's Avatar
i do it but i wouldnt say while im CASUAL driving. while im out playing having some fun i do it.
smurfkiller is offline
Old 05-15-2011, 02:26 PM
1 C6 2NV
Myth Buster
Support Corvetteforum!
1 C6 2NV's Avatar
I had to do it several times when running the Mile. My PP wouldnt release after high RPM runs. I wouldnt do it under normal driving conditions simply because the best rev match truly cant be determined do to the syncros still trying to do their job. Unlike an unsynced gear box you dont really get the feedback from the gear cluster to do it correctly
Last edited by 1 C6 2NV; 05-15-2011 at 02:28 PM. Reason: spell check was dissaebulled
1 C6 2NV is offline
Old 05-15-2011, 02:28 PM
youngrigo
youngrigo's Avatar
I always rev match when down shifting... Its just natural to me to do it that way. Puts less stress on the parts
youngrigo is offline
Old 05-15-2011, 02:39 PM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
(besides, it sounds so cool!)
KenHorse is offline
Old 05-15-2011, 02:41 PM
ub2slow2
Guest
Posts: n/a
I do it when I'm driving in town and I have to slow down quite a bit for a certain corner here and there. If no cars are behind me then I will heel/toe it but if there is traffic around then I will just hit it while the clutch is in to rev match. Also depends on what shoe's I'm wearing, some you can't heel/toe with worth a crap lol.
Old 05-15-2011, 02:52 PM
laconiajack
laconiajack's Avatar
I take pride in providing my passenger a smooth, jerk free experience when either accelerating or decelerating through the gears, and one cannot accomplish that without rather exacting rev matching. I also brake well in advance and at a uniform rate and then coast at the very end of a making a stop for the same reason. On the other hand, I can speed shift faster than you can blink if need be. I really enjoy driving a standard transmission smoother or faster than can be accomplished with an automatic, and telling the car when to shift, and into what gear, rather than visa versa. I think driving well, be it cruising or racing, is an art form, and something that should give one a real sense of accomplishment.
laconiajack is offline
Old 05-15-2011, 02:57 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Not only are you full of yourself, you are full of ****.
Racer is offline
johnodrake
Moderator
johnodrake's Avatar
Received 3,578 Likes on 1,619 Posts
Heel-Toeing has become a habit since Spring Mountain....
johnodrake is offline
Old 05-15-2011, 03:14 PM
florida john
florida john's Avatar
I always double clutch when shifting down, simply from habit.
florida john is offline
Old 05-15-2011, 04:02 PM
KBow_Photo
KBow_Photo's Avatar
St. Jude Donor '12
How do you do that? I'm new at driving a manual
KBow_Photo is offline
Old 05-15-2011, 04:39 PM
CorvetteMike68
CorvetteMike68's Avatar
CorvetteMike68 is offline
Old 05-15-2011, 04:44 PM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
if that's true, double-clutching, it means shifting to neutral first, letting out the clutch, then shifting to the intended gear and letting out the clutch. bringing up rpms in both maneuvers, too.
AORoads is offline
Old 05-15-2011, 04:45 PM
1 C6 2NV
Myth Buster
1 C6 2NV's Avatar
Im curious about this term "double clutching" I have operated some heavy trucks over the years and the term was used to describe the method for shifting a box that wasnt synchronized. Im curious if this is a caryover term? Why would you try to do this to a fully syncd transmission? Simply releasing the clutch in between gears? Im not sure I follow.
1 C6 2NV is offline
Old 05-15-2011, 05:03 PM
youngrigo
youngrigo's Avatar
There is no reason what so ever to be double-clutching these cars...
Old 05-15-2011, 05:05 PM
j_digi454
j_digi454's Avatar
The 08 and up A6's do this. Wish I could get my 07 to do it with an aftermarket tune.
j_digi454 is offline
Old 05-15-2011, 05:08 PM
forg0tmypen
forg0tmypen's Avatar
Hell I want to know what the heck this whole thread is about...I hate to admit that, but we all start somewhere.
forg0tmypen is offline
To Rev Matching
Old 05-15-2011, 09:45 PM
06 C6 vert
06 C6 vert's Avatar
I rev match all the time with my A6. No clutch peddle to hassle with and much faster shifts. A vette is not a sports car without the quick launch ,quick shifting A6 with paddles.
06 C6 vert is offline
Old 05-15-2011, 10:31 PM
Mark VerMurlen
Mark VerMurlen's Avatar
For my car, it helps to double clutch when shifting 1st to 2nd and 2nd to 3rd when the transmission is cold. It eliminates the slight clashing. Once the transmission is warm, its not needed.
I do rev match when downshifting while driving on the street to practice it. Its more critical on a on track than on the street.
- Mark
Mark VerMurlen is offline
Old 05-15-2011, 10:43 PM
Wayne O
CF Senior Member
Wayne O's Avatar
With the possible exception of when I'm coming to a stop (at a very low speed going into 1st) I always rev-match. Maybe it's just me but the geometry of the pedals makes it damn near impossible to do a traditional heel/toe. If I have to be on the brake when down-shifting I put the ball of my right foot on the edge of the brake pedal and roll my foot onto the gas pedal. It isn't totally kosher but it works. I remember a guy who used aluminum and plastic spacers to shim his gas pedal up to make it easier to heel/toe in his C6.
Wayne O is offline
Quick Reply: Rev Matching
