Drivers side heated seat not working at all.
Old 05-15-2011, 10:57 AM
forg0tmypen
forg0tmypen's Avatar
Default Drivers side heated seat not working at all.
I recently had my seats reupholstered to the 3lz dark titanium pattern on my 06 Z06. I now have found that the drivers side heated seat does not function at all. Now lets get the Florida jokes out of the way here: ...................... Back on topic: I have searched, and I checked in the fuse box by the passenger foot well, I pulled all 3 fuses, the 1 relay and the separate passenger and driver fuses in the box off to the right of the main fuses, and I found that everything appeared to be in fine condition, nothing blown. The passenger heated seat is working great. When I press the button for the driver side, nothing happens, the lights do not even attempt to come on. Ive also checked under the seat, Ive unplugged and replugged in all the wiring harnesses and still nothing. I know it was working fine before the seats were redone...any thoughts?? Has anyone experience this issue? Thanks.
EDIT: Ive also tried pushing the button on the drivers side once or twice and felt the seat but it did not appear to warm up. I don't know what reupholstering a seat would break the heater component....frustrating.
EDIT 2: Upon further inspection, it appears the the drivers side and passenger side heated seat fuses are the green 20A kind and the illustration shows there should be only a 15A blue fuse there, don't know if that matters...like I said it was all working before, now its not.
Old 05-15-2011, 11:34 AM
JJC5
JJC5's Avatar
I had the exact same problem with mine. It turned out to be a wire rubbing on part of the seat frame, underneath. It rubbed the insulation off the wire and shorted out.
Old 05-15-2011, 05:32 PM
forg0tmypen
I looked under my seat, all wires look fine, I do have a wiring harness not plugged in underneath, I had the seat out of the car last week and could not find where it went....it's white and square shaped.
Old 05-15-2011, 06:53 PM
crusher1
crusher1's Avatar
My passenger side did that after the dealership changed my sticking door on the ashtray...Before I bought the car the previous owner went to the dealeship to fix the door for me....About a month later I pushed the button and nothing. So I checked the pushbutton on the console and low and behold the connector in back was disconnected. Those clowns at the dealership must have done it ....Connect it back up and bingo she works like a charm.
Old 05-15-2011, 07:51 PM
StanNH
StanNH's Avatar
Received 1,219 Likes on 409 Posts
My bet would be the wiring harness. My seat heater stopped working a few years ago on my 2005 and that's exactly what it was.
Old 05-15-2011, 09:24 PM
forg0tmypen
Like I said I looked under the seat but I'll be damned if there wasn't a spot to plug it into...what's the heated seat harness look like anyways?
Old 05-15-2011, 10:42 PM
Garret
Garret's Avatar
I believe in the Beer Fairy
Take it back to where you had the seats done...why the heck should you try to figure it out if they broke it.
Old 05-16-2011, 08:50 AM
forg0tmypen
I'll look into this today. It's a little more complicated than you think, but I'll explore this option.
Old 05-16-2011, 06:32 PM
JJC5
JJC5's Avatar
There is a flat, white Molex plug that needs to be plugged in under the seat. That's the seat heater wiring.
Old 05-17-2011, 11:27 AM
Chevy Cust Svc
Chevy Cust Svc's Avatar
I would agree with taking it to who did the work on your vehicle. It would seem to me that they missed something when putting the seat back in.
Good luck with your repairs,
Brent
GM Customer Service
To Drivers side heated seat not working at all.
Quick Reply: Drivers side heated seat not working at all.
