How to use IPOD without nav or XM??
Old 04-26-2011, 06:39 PM
5knives
5knives's Avatar
Originally Posted by Sunset-C6
How about this from Best Buy.
http://www.bestbuy.com/site/iSimple+...&skuId=1175181
Compatible with Chevrolet 2003 - 2010 Avalanche, 2003 - 2005 Cavalier, 2004 - 2010 Colorado, 2005 - 2010 Corvette, 2007 - 2008 Equinox, 2009 - 2011 Express, 2003 - 2011 Impala, Suburban, SSR, Silverado and Tahoe, 2003 - 2007 Monte Carlo.
I think you might need XM or harnesses for it. If you look at the Vehicle Compatibility link, it mentions it at the bottom of the page. I might take a trip to Best Buy tonight to confirm.
Old 04-26-2011, 07:24 PM
0Double D Mods
Former Vendor
Support Corvetteforum!
Double D Mods's Avatar
St. Jude Donor '12-'13
Originally Posted by shado
Is installation the same as the PAL? Will this work on an '07 1LT w/o Nav/XM?
Remove radio bezel
remove radio
unplug factory harness form radio
plug in new isimple kit
plug into factory harness
route ipod cable
reinstall radio
reinstall bezel
thats it
work with or without NAV
Old 04-26-2011, 07:26 PM
0Double D Mods
Former Vendor
thats the same kit we sell for 75.00 less than Best BUy
operates off the XM band of the radio
as long as the XM portion of the radio was activated by the dealer during setup its fine. We have had only 2 cars that this was not done during dealer prep
simpl trip to dealer and problem solved
Old 04-26-2011, 07:37 PM
viper8u2
viper8u2's Avatar
I have been looking for an option for my 08 Z06 with Bose and Nav, I think its completely stupid that GM put an aux jack on the cheap radio but left it off on the supposed upgrade.....
All I want to do is be able to hook up my android phone through a aux jack. Now if any of these solutions add bluetooth so I can use that through the audio system that would be even better
Any ideas?
Old 04-26-2011, 07:39 PM
5knives
5knives's Avatar
Do they normally set it up even if it's not an XM radio? Mine is a base radio so I have no idea if it's set up for XM.
Old 04-26-2011, 07:56 PM
0Double D Mods
Former Vendor
normally yes
like mentioned we have only come across 2 cars that it was not done during dealer prep.
Once the radio was programmed the ISGM575 kit worked just fine
Old 04-26-2011, 07:58 PM
tclhb
tclhb's Avatar
Good info! Thanks!
5knives
5knives's Avatar
normally yes
Thanks...I just may be ordering this
Old 04-27-2011, 08:02 PM
Johnno52
Cruising
Johnno52's Avatar
I am an Ipod user and on my Avalanche I also use the Aux jack for the sound and the acc charger for the power. I found this messy and certainly will not use it in my coming C6.
I want my console to be clean and my solution is I loaded up my playlists on separate CD's using MP3 songs. I can put in up to 140 songs in each CD and 4 will suit me fine. This will give me hours of select music. I have a hard time seeing the Ipod screen while driving so switching the Discs is much easier and safer. The player will also read all your songs and you can select albums and artists or just play random songs.
If you have the 6 CD changer thats even better. Now all I need is my C6!!!!
Quick Reply: How to use IPOD without nav or XM??
