Still wondering which oil filter to use? Filter Comparison Chart within
Old 04-13-2011, 11:21 AM
FloydSummerOf68
FloydSummerOf68's Avatar
Default Still wondering which oil filter to use? Filter Comparison Chart within
Not the end-all be-all information, but it was intereseting none the less.
Full Article: http://www.gmtruckcentral.com/articl...lterstudy.html
Click on this link for the full grades all filters received.
http://www.gmtruckcentral.com/articl...gradesheet.htm
Of note, in this test the best filters were (there is a slight weight for price too):
1. Fram Xtended Guard
2. Mobile 1
3. Royal Purple
4. Aimsoil (tie overall score with below)
4. K&N (tie overall score with above)
Worst were:
1. Shell
2. AC Delco
3. STP
4. Proline
5. Fram High Mileage (it filters better than lower tier Fram, but is built poorly and costs more)
Old 04-13-2011, 11:39 AM
FloydSummerOf68
Links should work now
Sorry about that
Old 04-13-2011, 11:43 AM
tim414
tim414's Avatar
St. Jude Donor '12
2. Mobile 1
3. Royal Purple
Worst were:
1. Shell
2. AC Delco
3. STP
4. Proline
When you say that the AC Delco is one of the worst, which part number do you refer? The PF-48 OR the UPF-48R ????
Old 04-13-2011, 11:48 AM
vettedoogie
vettedoogie's Avatar
The Mobil 1 filter is not a C6 Corvette filter, neither is the AC Delco filter.
Old 04-13-2011, 11:59 AM
Top_Fuel
Top_Fuel's Avatar
I use the UPF48R. It's not expensive and I talked my dealer into ordering a case so they could sell me one.
Info on this filter here.
Old 04-13-2011, 12:00 PM
FloydSummerOf68
This is just a reference to how the particular filters are constructed and the quality found within them. I would assume that would be carried across the particular brands filter lineup.
Old 04-13-2011, 12:10 PM
tim414
tim414's Avatar
St. Jude Donor '12
Then the info is not exactly correct I would think. The PF-48 and the UPF-48R ARE different in their construction.
The latter is a HEAVIER constructed filter.....
As well, it has been stated here on this forum that there is only one or two companies that make ALL the filters we find on store shelves. Their manufactured to specs according to whose name is going on the filter.
this thread has had multiple runs here on this forum. so, cutting through the chase so to speak, PF-48 started out on C6Z and changed in '10's owner manual. Now, the UPF-48R is listed in my owners manual where the earlier version was before. It's constructed heavier because the ZR1's oil pump creates enough pressure to burst the earlier PF-48. So GM now calls for the UPF-48R for BOTH Z06 AND ZR1. (not that Z06 has the same pump as ZR-it does NOT)
But, the Z06 CAN still use the early one.
Old 04-13-2011, 12:16 PM
fnbrowning
fnbrowning's Avatar
Thank you for posting this test.
I wonder how many are going to bawl because their favorite ox is getting gored?
Kinda like the air filter tests where the cherished aftermarket air filter admirers squawk in protest when their performance filter fairs poorly!
Old 04-13-2011, 12:49 PM
superstreet
superstreet's Avatar
St. Jude Donor '10
For the most part,we have always used Wix filters.
Old 04-13-2011, 02:41 PM
Radioman
Support Corvetteforum!
Radioman's Avatar
Not to mention zaino...
Old 04-13-2011, 02:45 PM
C-INRED
C-INRED's Avatar
St. Jude Donor '06
Assuming anything will often make an *** out of u and me.
A commercial contractor once gave me that tip and it was an excellent one. I try not to assume anymore.
Old 04-13-2011, 03:18 PM
FloydSummerOf68
Yes, very clever...we've all heard that saying since we were 10
The chart is for nothing more than to just see how different brands faired against one another. The fact that they aren't specifically for the C6 is somewhat irrelevant in regards to the information it's trying to get across.
Like I said, it certainly is the end-all be-all report...it's just a tool to help make more informed decisions.
Old 04-13-2011, 03:41 PM
Pauls72
Pauls72's Avatar
Here is a different oil filter study with some different opinions.
http://people.msoe.edu/~yoderw/oilfi...dy.html#w51515
Old 04-13-2011, 03:43 PM
VET4LES
VET4LES's Avatar
Old 04-13-2011, 03:51 PM
redls3
redls3's Avatar
go with UPF48r its the best filter for the c6 and recommended by GM.
just purchased two at the dealer today list price is $16 for one.
Old 04-13-2011, 03:55 PM
vettedoogie
Just an addendum...at least both the Mobil 1 filter seems to be of the same TYPE of filter for the Vette. The "tested" Mobil M1-302 is an "Extended Performance Oil Filter" like the M1-107 is. One hopes they are identical in their performance levels.
JERGENSEN LS3
JERGENSEN LS3's Avatar
Location: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
I do not think price should factor into the grade.
I do not care how much the best filter costs....as long as it is the best.
To Still wondering which oil filter to use? Filter Comparison Chart within
Old 04-13-2011, 03:59 PM
JERGENSEN LS3
Did you expect GM to suggest another brand filter ?
Old 04-13-2011, 04:02 PM
redls3
redls3's Avatar
OBV not
Old 04-13-2011, 04:42 PM
SteveC68
SteveC68's Avatar
I hate for this to be my first post on this forum. But I've seen this same "filter test" linked to on forums for years as the final word on quality filters. Ask yourself this before you read this "test". What is the most important job of an oil filter? After you answer that question read the "test" and then ask yourself why this was the one criteria left out of the "test".
Quick Reply: Still wondering which oil filter to use? Filter Comparison Chart within
