Squeaky roof? So here is one dealerships fix
I brought my car in to finally have the squeaky roof fixed and the dealership's service center said they know how to fix that issue.
So......slather on gobs of industrial lubricant all over BOTH front and rear and hope for the best.
It didn't stop the squeak and when I removed the top this is what I saw -
No REALLY!?!?!?!?
No REALLY!?!?!?!?
I used the heat shrink tube method described in the sticky. Basically you put shrink tube over the two male pins shrink it on and then I cut off the excess in front of the pin but leaving enough to make sure it wouldn't get pushed off. I tried all the other fixes and this was the one that finally did it for me. Cheap easy to do and if it doesn't work then go through the sticky till you find the solution for you. Good luck!
Received 2,051 Likes
St. Jude Donor '13
There is a long, multi-step GM bulletin about how to fix the noisy removable roofs. You can find it here with Search, print out a copy and go through it step by step, or have your dealer do it under warranty.
Using what worked for me or Joe or Louie is a scattershot approach that might work or might just waste your time. My dealer and i went through the whole process before finding the solution, it turned out that my 2009 needed:
Rear targa latch adjusted
Front targa latches replaced and later adjusted
Superlube on weatherstrip (silicone grease was not enough)
Both door strikes replaced (loose & rattling)
Get the bulletin, do the bulletin, that should solve the problem.
Stealerships, gotta love 'em.
Just a little white grease on the pin holes and latch rollers does it in most cases. I installed an Elite Engineering tunnel plate at the same time as the longtubes and no more "creaking top".
Before you go back to any dealer, clean & lube everything as described here (post #2): http://forums.corvetteforum.com/c6-c...long-post.html
After about a year, my 09 top got noisy. Honestly sounded terrible... completely fixed with Super Lube ($6 from Ace Hardware), some clean rags & Q-tips. Put the top on soft blankets & carpet for easy access.
If the problem persists, at least you'll know more lube isn't the answer.
Also, it might be the hot weather makes the problem worse... from the above link:
"Unfortunately there is very little that you can do about infrequent noises due to thermal expansion. The good news is that in most cases it will cure itself in just a few miles. As the car goes from a cool garage to the hot sunny day or having been parked in the hot sun and then driven away it is bound to make some noise. Once each of the materials comes in to thermal equilibrium the noises should stop."
More ideas: http://forums.corvetteforum.com/c6-c...d-popping.html
No REALLY!?!?!?!?
No REALLY!?!?!?!?
St. Jude Donor '13
The lube specified in the GM bulletin is GM Superlube, and it contains Teflon. It has a slightly whiteish appearance but works better- Dielectric Silicone Grease was not enough to eliminate the final squeaks on my roof, but the Superlube did the trick.
After a year, I got tired of the whiteish residue that was visible when the top was removed, I went back to the silicone grease for the rubber but kept using Superlube on the metal parts. That's been working fine for over a year.
No REALLY!?!?!?!?
No REALLY!?!?!?!?
More lubricant is not necessarily better. Just mess-ier.
If it is considered 'routine' maintenance to reapply the superlube every so often, what do people do to clean the old stuff off? Any suggestions are appreciated!
St. Jude Donor '13
It kind of disappears by itself over time, but I wipe down the rubber with paper towels before applying a new coat. As CO Lightfoot said, more is not necessarily better. I apply it in the sun on a warm day, work it into the rubber, and wipe off most of the excess.
I must be putting too much on as the old stuff definitely needs to come off but I don't think a paper towel will do it. I gets dried on. This is such a pain in the ****.
Anyone else have issues when they take the top off getting grease all over the place?
St. Jude Donor '13
Sorry for misleading you.
