Specs for rear license plate screws
Hi,
I just took delivery of a 2007 Z06 and noticed that it didn't come with any screws/bolts for the rear license plate.
Does anyone have the specs for these? I'd like to avoid playing trial and error since I'd probably end up crossthreading them.
Go to your local Ace Hardware and check out there nuts and bolts section. One of the trays is labeled "License Plate" and you will find what you need.
Advance auto
Go to advance and for less than 2 bucks you get the plugs with screws if you have the plugs just use the screws if not you now also have the plugs you need as well and for 2 bucks its right.
Good luck, Jeff
Received 2,047 Likes
St. Jude Donor '13
The replacable plastic plugs in the car appear to be "blank", your screws will cut the threads as you install them.
There is a certain amount of pliability there, I switched back and forth from fine threads to coarse threads a couple of times when I didn't have the right screws, worked fine. Finally, I got new plugs and carefully drilled out the old ones, stayed with one size/thread of screw after that.
