Remove Rotors
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,830 Likes
2015 C7 of the Year Finalist
I don't think there is a nut holding on the rotors? The calipers come off and then the rotors should pull off without removing the hubs.
Elmer
Elmer
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
No bolts but there may be speednuts over a couple of lugs.
(and of course, if you're pulling the rear rotors, make sure your parking brake is NOT set).
Rotor
The only thing you have to do is remove the Calipar Braket and the rotor flopps right off. Here are a couple of pics of when I powder coated the rotors. The bracket has two bolts on the back side you remove. Then rotor comes off. If it is hard it may be because of the rust on the center point. Just keep working it and it'll come off. Hope this helps.
TIM$VETT
Yep, you are right about the speed nut. Take a screw driver and knock it off. Then they'll slide off. Sorry, I forgot about those.
TIM$VETT
You guys who say there are no "nuts" holding the rotors on are simply WRONG.
I have yet to see a stock Vette that didn't have speed nuts over at least 1 lug.
If they're not there, they have been previously removed.
