60 LED Switchback DRL/Turn Signals @ JWM
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Switchback on right side of the car in the pic (cars left)
Video
Enhance the front of your C6 with our 60 LED switchback DRL bulbs.
Operation
Amber with lights off. Turn signals are amber.
White with lights on (and/or fogs). When turn signals are applied they flash between the white and amber.
You can expect your blinker to blink a little faster than stock. Load resistors are now an option to control this.
Load resistors are now an option. They will stop the hyperflash.
Make sure when you order you select 1 (for a pair)
$45 each pair (2) shipped in the US!!
Order here
Directions are on the site for the DRLS and the load resistors!
Banned Scam/Spammer
Hmmm. I don't know much about videos really. What I did was change my settings for privacy. I guess they changed that after I had these uploaded.
I'll see if I can get them to youtube.
The videos from your older posts did not work for me. This time they worked perfectly.
I know this has been asked before, but as a point of clarification...under NORMAL daylight operation with headlight set on "AUTO," the daytime running light is still amber, right? The only way to have the white running light is to have headlights and/or foglights on?
It's too bad there isn't a way to have the running lights white under NORMAL daylight operation. That's probably what the majority of potential buyers would prefer.
Banned Scam/Spammer
White with lights on (or fogs). They switch between the colors when turn signals are applied.
We have all white DRLS for those that want white http://www.shop.jwmotoring.com/produ...0&categoryId=6
They use the more powerful signal light filament as the DRL's during the day (headlights off) and the lower power filament at night (headlights on). Therefore the signal lights are always amber but the DRL's are amber in the day and white in the evening because of the filament change when using these swithchback LED bulbs.
