Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-08-2011, 01:18 AM   #1
koon5
Junior Member
Default Driveway curb ramps
I'm afraid I'm going to scrap the front of my corvette as I come out of my driveway into the street because it has a steep drop-off. Anyone know someone/place that sells driveway ramps? Or does anyone else have this problem? what do you do?
koon5 is offline   Reply With Quote
Old 03-08-2011, 01:26 AM   #2
keyplyr
CF Senior Member
keyplyr's Avatar
From an earlier thread:
Quote:
Originally Posted by valleygrandsportc6 View Post
I installed these because I have a very steep curb due to being at the bottom of a him on a cul-de-sac. Great product no more scrapes. Not even for the air damn.
http://bridjit.com/
The SEARCH utility is your friend
keyplyr is offline   Reply With Quote
Old 03-08-2011, 10:14 AM   #3
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
Some minor front end scraping (of the diffuser) isn't going to cause a problem...its flexible and designed to take abuse. If you're hitting something hard then you do have a problem. I'm sure you've tried traversing the drop-off at different angles to see if that minimizes or eliminates the scraping. Some type of removable ramp might be the answer but IMO removable, unsecured ramps might become dislodged by heavy trucks or possibly even stolen by neighborhood pranksters. I'd explore adding a small concrete or asphalt cam strip onto the drop-off (to reduce the approach angle). It may not be permissable due to governmental regulations or subdivision CC&R's but IMO it would be worth looking into. I don't know what your situation is but I'd be inclined to put a small cam strip in and see what happens. As long as it isn't causing drainage issues chances are no one will have a problem with it. Worst case you get a notice and have to remove it. Good luck.
__________________
2005 Corvette C6 Coupe
Magnetic Red Metallic II/Cashmere, MN6, 1SB, F55
Lingenfelter 403 Conversion, LG Pro Headers (coated), Corsa Sport Exhaust, Lingenfelter CAI, Accusump, LGM Coil-Over Suspension & Bump-Steer Kit, T1 Sway Bars, Pfadt Control Arm Bushing Kit, Elite Eng. Tunnel Plate & Oil Catch-Can, SKF Racing Hubs/Bearings, AP Racing Brakes, DRM Brake Ducts, Custom Roll Bar, Sparco Seats, Wide-Booty, CCW C10 Wheels,
Setup: LG Motorsports
Thanks to: 21st Century Muscle Cars
Wayne O is offline   Reply With Quote
Old 03-18-2011, 11:16 PM   #4
TB427Z06
CF Senior Member
TB427Z06's Avatar
Quote:
Here's my solution: 2'X2'X1" rubber tiles. I've got a 1 1/2" drop off the end of my driveway into the road. My air dam would drop hard into the driveway and scrape for the last 6 inches or so till it cleared. Also my front splitter would scrape if not at an extreme angle. Now no scraping at all. They are called 1" eco-tiles and are made from car tires. here's the link: http://www.rubbercal.com/Eco_Sport_1_Inch.html
Click the image to open in full size.
TB427Z06 is offline   Reply With Quote
Old 03-18-2011, 11:40 PM   #5
mack morrow jr
CF Senior Member
mack morrow jr's Avatar
i PARTIALLY FILLED MINE WITH SOME CONCRETE.
mack morrow jr is offline   Reply With Quote
Old 03-18-2011, 11:44 PM   #6
C6LS3
CF Senior Member
C6LS3's Avatar
[QUOTE=TB427Z06;1577097661]Here's my solution: 2'X2'X1" rubber tiles. I've got a 1 1/2" drop off the end of my driveway into the road. My air dam would drop hard into the driveway and scrape for the last 6 inches or so till it cleared. Also my front splitter would scrape if not at an extreme angle. Now no scraping at all. They are called 1" eco-tiles and are made from car tires.
nice tip! you can get them at sears.com too
C6LS3 is offline   Reply With Quote
Old 03-18-2011, 11:50 PM   #7
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '11
Racer's Avatar
I just put the ZR1 splitter on my wifes Vette and I am doing some damage on my Fcar so I am finally buying these this year.
Racer is offline   Reply With Quote
Old 03-19-2011, 06:24 PM   #8
TLK
CF Senior Member
St. Jude Donor '09-'11
TLK's Avatar
http://www.bridjit.com/
http://www.griotsgarage.com/product/...curb+bridge.do
http://www.carguygarage.com/singlecardrivew.html
TLK is offline   Reply With Quote
Old 03-19-2011, 09:55 PM   #9
2011owner
CF Member
I have about a 3 1/2 to 4 inch drop. I place a couple of 2 x 4s there when I go in or out of the driveway. No scrapes and cheap. Going to purchase a 2 x 12 as soon as remember to hit the store. 2 3foot long pieces should work nicely and are a very cheap fix.
2011owner is offline   Reply With Quote
Old 03-19-2011, 10:19 PM   #10
CF Senior Member
St. Jude Donor '11
Racer's Avatar
Quote:
That works, but kind of brings down the neighborhood a bit don't ya think?
Old 03-19-2011, 10:23 PM   #11
Steve D
CF Senior Member
Steve D's Avatar
Send a message via AIM to Steve D
Quote:
Yeh, looks like a real ghetto
Steve D is offline   Reply With Quote
Old 03-19-2011, 10:27 PM   #12
jim02C5
CF Senior Member
St. Jude Donor '12
jim02C5's Avatar
I have the Bridjit system in my drive and I still scrape although nothing like I used to. My C5 is lowered on Pfadt c/o's and I have a set of the Fat Mommas sold by a forum vendor. I like the Bridjit but with as steep an incline as I have, they just help out, not eliminate the problem. Mine also seem to "migrate" down the curb every couple of days, they are heavy but I drag it back in place every weekend.
jim02C5 is offline   Reply With Quote
Old 03-19-2011, 10:33 PM   #13
CF Senior Member
St. Jude Donor '11
Racer's Avatar
Quote:
Well if you are disagreeing with me, no problem.
All I know is, if my neighbors had 2x4's lying on the road at the base of their driveway, yea, I'd be pissed! looks like crap!
Old 03-19-2011, 10:33 PM   #14
SlasherMcGee
CF Senior Member
SlasherMcGee's Avatar
If I installed one of those things the city would sue me 6 ways from Sunday.
SlasherMcGee is offline   Reply With Quote
Old 03-19-2011, 10:35 PM   #15
CF Senior Member
St. Jude Donor '11
Racer's Avatar
Quote:
In our city, as long as it isn't bolted down, has a relief for drainage, doesn't interfere with street cleaning and/or snowfall and doesn't look like crap (2x4's) your ok.
Old 03-19-2011, 11:03 PM   #16
c6coop
CF Senior Member
c6coop's Avatar
Is that the people or the approach thing?
coop
c6coop is offline   Reply With Quote
Old 03-19-2011, 11:43 PM   #17
C6 Don
CF Senior Member
C6 Don's Avatar
KY
I was at Home Depot tonight and they have them for $6.99 each.
C6 Don is offline   Reply With Quote
Old 03-19-2011, 11:57 PM   #18
diyguy
CF Senior Member
diyguy's Avatar
On my way home from work everyday, there is a dip in an intersection / street (not even close to my house) that is simply unavoidable and it turns heads when the rubber air damn hits it every single time. Sounds horrirble, but when checking for damage, it is hardly noticeable. The air damn has springs so it 'folds under' for that very reason.
I'll just replace the whole thing for less than $100 when it does show significant wear. No harm, no foul.
diyguy is offline   Reply With Quote
Old 03-20-2011, 12:50 AM   #19
2011owner
CF Member
i remove the 2x4s after I come in and out of the driveway. I don't leave them sitting out there as you some of you have stated it would look ghetto.
2x4s are temporary as they were laying around. Worried if I purchased something like the ramps and left them there some smart a$$ little punk would come by and take them.
Old 03-20-2011, 12:54 AM   #20
CF Senior Member
St. Jude Donor '11
Racer's Avatar
I was wondering the same about the ramps being stolen, but they are bolted together and they weigh like 160 lbs and not real maneuverable so I think they are safe.
Reload this Page Driveway curb ramps
Tags
bridjit, c6, car, corvette, curb, dealer, diego, driveway, issues, location, ramp, ramps, san, steep, street
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
BRIDJIT Curb Ramp 3 Piece Magnum_Steel C6 Parts for Sale/Wanted 1 01-07-2014 09:33 PM
Driveway Curb Transition/Ramps Too-Fast C6 Z06 Discussion 1 06-20-2013 02:14 PM
Do I really have to cut my exhaust off???? projectcop C5 General 16 05-18-2013 12:12 PM
lifting idea...safe? RockyMountain Z C6 Z06 Discussion 16 10-13-2012 12:41 AM
Steep (unusual) driveway Henry1210 C5 General 21 07-19-2012 09:13 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
