Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-07-2011, 09:00 PM   #1
Lubrecon
CF Senior Member
Default GS Pedal Covers
Has anyone purchased the GM pedal covers for their GS? Are they hard to install? I did not order that option, but can get them for about $200. Just wondering if I should?
Lubrecon is offline   Reply With Quote
Old 03-07-2011, 09:05 PM   #2
bigblock427
CF Senior Member
bigblock427's Avatar
Brent Morgan Brent Morgan
I did not order mine. My Vette came with them. One of only three options that were on the car. I could look at them to see how they were installed and let you know.
bigblock427 is offline   Reply With Quote
Old 03-07-2011, 10:28 PM   #3
Lubrecon
CF Senior Member
Thanks. The gas pedal looks like a complete assembly and other two look like the just fit over or on the existing pedals.
Any help is appreciated.
Old 03-07-2011, 10:31 PM   #4
bigblock427
CF Senior Member
I will check tomorrow and let you know what I find.
Old 03-07-2011, 10:38 PM   #5
CrvtBB
CF Senior Member
CrvtBB's Avatar
I bought the same type of setup for my CTS. The accelerator is a complete assembly. It is actually the easiest part of the changeout - pretty much plug and play. The brake and clutch are new covers and it took me quite a while wrestling with the brake cover to finally get it on. Once on, I definitely think it was worth it though. I'm definitely considering it for my GS.
CrvtBB is offline   Reply With Quote
Old 03-07-2011, 10:44 PM   #6
tonyasc6
CF Senior Member
tonyasc6's Avatar
tonyasc6
You are correct. Thats exactly how they install. The gas pedal is a complete switchout. The other 2 slip over the existing pedals.. Its easy to do.. I installed mine. You can do it!!!!
Mines not a GS but I'm sure the install is the same...
tonyasc6 is offline   Reply With Quote
Old 03-07-2011, 11:05 PM   #7
george vee
CF Senior Member
Support Corvetteforum!
george vee's Avatar
I bought the Elite Engineering gas and dead pedal, easy install.
Click the image to open in full size.
george vee is offline   Reply With Quote
Old 03-07-2011, 11:13 PM   #8
fmarshall
CF Senior Member
fmarshall's Avatar
I have an MN6. Bought mine from GS creations.
http://www.gscreationsllc.com/produc...roducts_id/394
A C-clamp and a 7/16 socket made easy work of the accelerator pedal.
The key is to first use a mirror to look behind the pedal to understand how everything is arranged. Then unhook the spring from its lever and use the c-clamp and socket.
fmarshall is offline   Reply With Quote
Old 03-07-2011, 11:19 PM   #9
cmonkey713
CF Senior Member
cmonkey713's Avatar
I just installed the Elite pedals this weekend. The gas pedal was imposable to install without dropping the pedal hanger to adequately access the back of the pedal. If I would have done this in the first place I could have knocked off an hour instead of fooling around with it and just getting frustrated. I would highly recommend to anyone doing the install to just drop the pedal hanger for easy access.
cmonkey713 is offline   Reply With Quote
Old 03-08-2011, 03:29 AM   #10
CrvtBB
CF Senior Member
CrvtBB's Avatar
Quote:
I should also note I bought the GM Accessories pedal/cover; similar to the one's offered for the Corvette except with long strips of rubber against the aluminum instead of squares. If you go aftermarket, your install experience might be different.
Old 03-08-2011, 08:58 AM   #11
Vette5.5
CF Senior Member
From experience, any time you're working on the gas pedal, it's easiest to pull out the entire assembly. No big deal, as only three bolt's and a plug in wire harness. I tried the Elite wide pedal, but didn't care for the sloppy mounting set up. Ended up with a wider bolt on piece, but that's a whole nother story.
Vette5.5 is offline   Reply With Quote
Old 03-08-2011, 09:32 AM   #12
spinalator
CF Senior Member
spinalator's Avatar
Send a message via AIM to spinalator
I got the GM accessory pedals. For the brake cover, I suggest place it in near boiling water to soften up the rubber before trying to get the brake cover on.
spinalator is offline   Reply With Quote
Old 03-08-2011, 09:47 AM   #13
Walt White Coupe
CF Senior Member
Walt White Coupe's Avatar
Here's another alternative: http://www.pfyc.com/pc/C62039/C6INT/....html#moreinfo
Walt White Coupe is offline   Reply With Quote
Old 03-08-2011, 10:53 PM   #14
Lubrecon
CF Senior Member
Thanks for the pictures....I really like the GM ones. I'll get them and put them on.....as soon as I get my new GS, which was supposed to be yesterday, but will be Thurs I hope.
Old 03-09-2011, 05:18 AM   #15
Don-Vette
CF Senior Member
Don-Vette's Avatar
Thanks for that link!!!
Don-Vette is offline   Reply With Quote
Old 03-17-2011, 11:41 PM   #16
Z06LUST
CF Senior Member
St. Jude Donor '12
Z06LUST's Avatar
Thanks for all the pics and comments guys. My GS order goes in tomorrow through Ken Fitchner...was debating whether to add these to the order or do it myself later..
Z06LUST is offline   Reply With Quote
Reload this Page GS Pedal Covers
Tags
c4, c6, corvette, cover, covers, dead, gs, gspedal, install, installation, pedal, pedals, pedel, petal, review
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
