POLL: LED Reverse Lights - More light or Less light than stock?
I am curious to see what other owners that ALREADY have done the LED reverse lights think about the amount of light that it casts compared to the stock ones:
I say LESS light...
I say LESS light...
Received 2,054 Likes
St. Jude Donor '13
Where's the Poll?
I would have to Vote...Less Light...when installing the LEDs... I had to configure a mirror so I could see if they were on after I had installed them and that was in a darkened garage. Stock bulbs could easily be seen reflecting light off the garage door...not so with the LEDs... I still like the White light though...
An important question. The sole purpose of back-up lights is to see behind you so you don't back-up into something or someone. The look of the back-up lights themselves, or the current drain of them when illuminated, or the life of the bulbs, are of no consequence because of the brief and infrequent times they are actually used. The only thing that matters is how well you can see things behind you when they are on. So far it looks as though LED back-up lights are a really poor modification, and a total waste of money. Thanks OP for taking this pole.
I went with the super bright ones from JW Motoring and they are brighter than stock. Dont know about the regular ones, but these are real bright and like said, look 100% better than stock. All plug and play. Ive switched every light on my car to LED inside and out.
One last thing.....I have the super bright led reverse bulbs for people to see me. Once again, because my lights are so low to the ground and most people don't see them or they don't grab other drivers attention...especially with the dull yellowish OEM bulbs.
I think that the 'normal' LED backup lights are similar to the stock ones in brightness BUT are whiter as opposed to yellowish. They do look better when lit up but as other have said, "What value that is to you depends on your prospective."
I just bought the 'Super Bright' LED backup lights (only $25 so worth a try) and I will post up some comparison photos within a few days.
St. Jude Donor '13
If the C7 is delayed a while, maybe we'll get a factory backup camera in the C6.
So you have been hit a whole bunch when you have been backing up?
What car are you driving because I drive a C6 corvette. On MY car the backup lights are low to the ground and just about useless for the most part. Will it light up a car or wall so I can use my eyes to guess how much room I have, sure. Will they light up my driveway when reversing out of it so I can see anything that runs in my path, no freakin way. You want the best reverse protection, install a rear backup camera like it did. /thread
When do they look better and who do they look better for, Joe blow when you are backing out of a parking stall? I bet he is not saying, nice mod on that Corvette, I would think he is saying something more along the lines of "finally a parking spot!"
i got these for $15 shipped and the work great. Nice for when you walk up to your at night , they really light up the area behind the car, if you use your fob to unlock .
Last edited by Tact; 02-28-2011 at 08:11 PM. Reason: Non supporting vendor links NOT allowed
