Safelite autoglass and OEM glass
They use cheaper glass. This is a quote from the Safelite website.
What is the difference between OEM and OEE glass?
We manufacture and install OEM-equivalent, or OEE, auto glass. This means that it is essentially the same piece of glass that is installed at the time your vehicle is made, with the only difference being the windshield manufacturer.
Our glass meets or exceeds all federal, industry and safety standards, and we engage in some of the most rigorous product testing in the industry.
I have no experience with Safelite.
I work at a dealership and we use a local glass shop that also installs aftermarket windshields at times if the customer requests a cheaper price.
We have had no issues with aftermarket glass, as long as it's installed by a qualified, experienced installer.
Only issues I've seen is water leaks from improper installation.
Is this for a Corvette with HUD?
I 've been using Safelite glass for years. I can't count how many times, but at least never on the Vettes. While their service is prompt, and they come to your door and do the job from a mobile truck, the fact is the glass is not as good as oem and never has been for me. I've got a brand new windshield they just put in my truck, it's just a bit wavy when I look through it at certain angles, not terrible but not as good as new and never has been whenever they've replaced one for me.
It doesn't have to be done at a dealer. Call a local glass shop and specify that you want an OEM glass. Be sure to mention you have HUD.
Nope, I've always used Safelite, their service is so good I keep overlooking the flaws and go back to them. They do a good job on the install. The glass itself looks like a match, has the right tint, the right masking and always fits good, but always seems to have a bit of that optical distortion that was absent in the oem piece.
Location: Cape May, NJ; Guntersville, AL; Orange Beach, AL
I had a Safelite windshield in my 08 Tahoe when it got smashed on a roadtrip. I could tell no difference. As far as the HUD windshield I have seen HUD's in both HUD windshields and nonHUD windshields and there is almost no difference. I don't think there is any problems with their glass. The problems with windshields is the actual installation not the glass (at least in 99% of the problems). If I needed to use Safelite on my Vette I would do so with no worries.
No matter the quality of service or fit of the glass I don't feel that looking through a distorted windshield is acceptable. It's a constant reminder that the glass is not up to OEM standards. I wouldn't buy a new car with a glass issues like this. Why would I accept inferior glass as a replacement?
I reduced the Corvette tax (which is in full effect on windshields) by getting the non-OnStar glass(PPG) from a 2005 vette. so you don't get the mount or the shaded section to mount the antenna, but it was a lot cheaper.
Oem
I had my insurance company authorize OEM replacement glass in my '07 because I have the HUD. It took about a week for the OEM windshield to arrive at the Safelite shop - then they came by an put it in. Go with OEM, there is a difference.
Oem
Safelite NO WAY. I own a glass replacment shop and have been putting in glass for 22 years and I would take it for in shop service. You can solve problems when they come up and in my shop I have 7 people that pull together to solve the problems that can come up when installing glass. OEM glass only in my Corvette anything else and a fight is on I have seen some really crappy aftermarket glass but if I did not have insurance I guess I would have to do some shopping. No way I'd have someone put a windshield in my car in a driveway . I also would not want someone to come and make a pizza in my driveway.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
Safelite did quality work for me 2 years ago. The windshield was not OEM but met the same specs and looked exactly like the original right down to the shading at the top. Perfect install, no leaks, no mess, "like it never happened!"
CF Senior Member
I've used Safelite numerous times with Suburbans I've owned and most recently with my daughter's car...I've never had any issues with their glass or service. Actually, once on my Suburban there was a slight leak around the seal but they came back out and fixed it. I don't know but its possible the glass Safelite uses is made by the same sources that manufacturer's use with the only difference being the branding. Again, I don't know but I've never had problems using Safelite.
I recently replaced the HUD windshield in my C6 at a Buick dealership of all places....with years of track use the windshield had a few small 'chips' and generally looked sand-blasted. The Buick dealership has a specific glass company they use for installations but they assured me they would get GM replacement glass. What I found interesting...with full glass coverage on my insurance the glass company got me on a three-way call with the 'insurance' company to verify coverage and approve the work. Surprisingly, it was Safelite Glass that was handling the claim for the insurance company. Evidently, many large insurance carriers use Safelite to handle all their glass claims irrespective of which glass company does the work.
I have used Safelite several times. I always request oem glass. It does take a few days longer to wait for the glass to come in. Never any problems with quality of work or with the glass.
Priming
Two important parts of the install is primming scratches made when removing glass and the quality of the urethane used. Priming scratches made when removing glass is important because you do not want to end up with rust. I have seen a lot of rust come from improper priming like holes you can stick your fingers in . MAKE SURE SCRATCHES ARE COVERED WITH A GOOD URETHANE PRIMER
