Old 02-20-2015, 06:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
C6 Corvette Won't Start
Old 01-30-2011, 08:45 PM
gunther2000
gunther2000's Avatar
Default C6 Corvette Won't Start
Hello everyone. I'm looking for some help for my 2005 C6 Z51. The problem is that it doesn't start everytime. I've read some other post with similiar problems, but I can't find anyone who says what the fix was. The clutch is all the way to the floor, the battery has plenty of juice and the FOB is detected. The guages sweep and all light come on, but the engine doesn't turn. I will disconnect the battery for a few seconds, then reconnect it and it starts fine. This is getting old. Has anyone else out there had a similiar problem and found a fix for it? Thanks for the help!
gunther2000 is offline
Old 01-30-2011, 09:41 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
You might think the car battery is okay, but it sounds like it's about to go down for the count. Those are the first symptoms of a dying C6 battery according to what's been posted here many times.
Vette_DD is offline
Old 01-30-2011, 09:47 PM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
Jim's correct, and there's more. There is no ONE fix since like anything, it could be one thing on your car, and another thing on another car. You need to look at the most likely culprits, and some that are a bit more unusual or not ordinary.
So, take a look at this thread, too, but don't discount it is your battery.
http://forums.corvetteforum.com/c6-c...t-gremlin.html
AORoads is offline
Old 01-31-2011, 06:39 PM
gunther2000
I was thinking it was the battery at first too. I replaced it 1 1/2 years before I started having problems. I thought I got a bad battery at that time so I brought it into Auto Zone to test it. They tested my old battery and said it was fine, but I know the guy who works there and he gave me a new one anyway. The problem keeps happening. I will drive in the area and when I shut down, I show 14.4 volts on the dash. I'll try starting it two minutes later and I get nothing. I'll disconnect the battery and reconnect it, and the car starts right up and shows 14.4 volts on the display. I'm afraid it could be anything, but I received a great email saying to look at the steering column lock.
We're having an ice storm right now, so it's going to be a while before I can get the car to the dealership. I'll post what they tell me. Thanks for the help and keep posting if you have any other experiences like this!
Old 01-31-2011, 06:41 PM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes on 2,065 Posts
2015 C7 of the Year Finalist
Look at the battery post connections. Any trace of "green" on them?
Elmer
eboggs_jkvl is offline
Old 01-31-2011, 07:09 PM
gunther2000
I used a battery cleaner on the terminals and cables when I put the new battery in. It's as clean as I can get it.
Old 01-31-2011, 07:16 PM
Guyver
Guyver's Avatar
Steering colum lock is my guess also. If u disconnect then reconnect battery, then that shouldnt be the issue. Just saw this problem not long ago and it was the sensor in the colum. Good luck
Guyver is offline
Old 01-31-2011, 07:30 PM
StKnoWhere
StKnoWhere's Avatar
Check the connections at the starter also.
http://forums.corvetteforum.com/c6-t...m-message.html
StKnoWhere is offline
Old 01-31-2011, 07:32 PM
blwn_08
blwn_08's Avatar
push the clutch in first
blwn_08 is offline
Old 02-01-2011, 12:33 AM
cclive
cclive's Avatar
The 14.4 that you are seeing is the system voltage supplied by the alternator...it is not the resting voltage of the battery. When it won't turn over, I would take a voltage meter and check the battery at the terminals. The DIC is no good for this as it only gives a reading when the ignition is on. I agree with the above though, a column lock issue is a very good possibility also. There is the starter relay in the underhood fuse box that you might pull and clean the terminals too.
cclive is offline
Old 02-01-2011, 02:57 AM
bigred6906
bigred6906's Avatar
Brother, this happened to me and I had my car sent to the dealer on a flatbed. It was a loose starter plug. The tech (good friend of mine) fixed it in a minute. He just tightened the plug back up and I've never had another issue.
bigred6906 is offline
Old 02-01-2011, 03:07 AM
tt3000gt
tt3000gt's Avatar
Same thing happens to my 05, I have to disconnect the battery and reconnect it and it starts up right away.. But I have to do this at least once every 2 days. Never had time to get it fixed, but if it is as simple as getting a starer plug tightened, then I'm going to dealership tomo! I've always just assumed it was something much more serious
tt3000gt is offline
Old 02-01-2011, 03:29 AM
bigred6906
bigred6906's Avatar
symptoms: Gauges swept, lights turned on but then nothing more would happen. At that point, if I pressed the start button again, everything would shut off. This cycle continued over and over.
Old 02-01-2011, 09:12 AM
haljensen
haljensen's Avatar
What is a "starter plug"?
haljensen is offline
Old 02-01-2011, 12:31 PM
cclive
cclive's Avatar
My first question when I read that...
cclive is offline
Old 02-01-2011, 01:57 PM
ABQ C6
ABQ C6's Avatar
Location: Somewhere you've probably never heard of in New Mexico
St. Jude Donor '11-'13-'14-'15
I had the same symptoms. It would eventually start sometimes it took 10-15 pushes on the start button. Dealer said they found a short in the wiring harness from the battery to the starter after they replaced the alternator twice. Gotta love electrical problems.
ABQ C6 is offline
Old 02-01-2011, 03:15 PM
gunther2000
Thanks for the hint. I usually quit pushing the button after 5 tries. I'll try pushing the button more next time this happens and see how that works. I am getting very tired of disconnecting the battery and reindexing my windows.
To C6 Corvette Won't Start
Old 02-01-2011, 04:40 PM
bigred6906
bigred6906's Avatar
I don't know exactly because I wasn't the one who fixed it, but my tech told me that it was a loose starter plug. I'm assuming it is some connection to or from the starter. He told me it was loose and he tightened it back up in a minute.
Old 02-01-2011, 05:47 PM
Hoonose
Hoonose's Avatar
Also check the battery ground.
Hoonose is offline
Old 02-01-2011, 06:00 PM
king off the hill
king off the hill's Avatar
Originally Posted by gunther2000
thanks for the hint. I usually quit pushing the button after 5 tries. I'll try pushing the button more next time this happens and see how that works. I am getting very tired of disconnecting the battery and reindexing my windows.
ok here u go .if your batt is 12months old its done in.no iffs or butts thats it.even if u do a load test.2005 working on no 6 i have had them pass but there still no good. Cold weather here. At least 6 months of the year.
king off the hill is offline
Quick Reply: C6 Corvette Won't Start
