Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Why Wont My Vette Start?
Guide to diagnose trouble with recommended solutions.
C6 Corvette Won't Start
My 05 did that a few times.I'd get clicks or just no starts.I just kept trying till it started.Once,I parked it while going out to dinner.I got out and noticed I was a little to close to the car in front of me so I got back in and bingo,lights,camera..but no action!!I waited a few seconds and she started right up.Might just be another quirk of the 1st year c6.
I'm starting to see a trend that people with 05's are saying it's a steering column problem. I didn't have this problem before I brought my vette in for the recall on the wiring harness in the steering column. It started soon after the recall was completed. I'm wondering if the mechanic did something when he took the steering column apart to look for the rubbing wires as the recall calls for. I'm going to bring my car back to the same dealership to try and fix it.
I've been driving the car for the past 5 days with no problems. It sat in my garage without a battery charger for 3 weeks and started right up. I've turned it on and off at least 20 times in 5 days without a problem. I don't think it's fixed, but I don't want to take it to the dealer and have them charge me $100 to say they can't find anything wrong. I'm going to have to drive around with my 10 mm socket so I can disconnect and reconnect the battery when it happens again. I guess the C4 people are use to carrying around a wrench for the targa top so I'll get use to carrying one around too. I'll post again if it goes bad again. Thanks for all of your help. This forum has been great!
This happens once in a while on my 08. Push the clutch in hit the start button and nothing, very unsettling. Will start on the second try. I may have the dealer check this out at next oil change if it becomes more frequent.
Twelve Month Old Battery Not Done
I have a 2005 and got 5 years out of the original battery. I only put it on charger a few times when in winter storage. After hearing about all the problems, I planned on replacing the battery in the spring (four years old) and did not use a charger in the winter. After sitting 3 months, on a warm winter day, I decided to get something out of glove box. I wondered if the door would open. It did. I tried starting the car and there was just enough juice to start it. I kept the battery for another year.
My 05 has a stock battery too..... Ive never heard of a quality battery lasting 12 months. Saying that I fell Ive got my use out of it an she will be changed this year......
What is the deal with the windows when you change the battery?
Someone earlier mentioned something about that...Im confused.
1.With the door closed, put the window all of the way down.
2. Raise the window with the window switch on the door all of the way up and hold up until you hear a click, then let go of the window switch. (Apprx 3 seconds)
3. Put the window switch to up again until you hear another click. (Approx 3 seconds)
4. Your windows are reindexed.
It's happening again. Thanks to a few post, I checked to see if my steering wheel was locked when it didn't start and it was not locked. When I disconnect and reconnect the battery, the steering wheel locked and the car started. It looks like I have a steering column lock problem. I'm dropping it off at the dealer on Thursday to have it fixed. I'll post one last time after the dealer fixes it.
Tricia, GM Customer Service.
#34
Received 1,501 Likes
I have a similar problem and does not occur as frequently, have had the problem since the car was new and it is not the battery, probably a software glitch. There is no fix for this.
#36
The dealer had the car and could not figure out what was wrong either. The car started evey time for them even though it’s left me looking foolish in many parking lots disconnecting and reconnecting the battery. The mechanic looked for service tech bulletins (I think that’s what they’re called) and found one put out in September that describes the exact symptoms we’re all experiencing. The fix is to replace the steering column motor at the cost of $1000! The dealer had to order one and it hopefully will be in today. I may not get the car back until Monday. I love Corvettes, but I wish they didn’t break as often as they do. It would be nice if GM did a recall on this. It would make me feel more comfortable buying the first year of the C7. The first year of the C6 seems to have a problem.
#37
The Technical Service Bulletin (TSB) is #PIC5367. The dealer I brougt my car to is Jack Schmitt Chevy in O'Fallon, IL. They were able to find the TSB and fix it. I had them do an oil change while it was there and the total bill including tax was $1128.62. There goes the new exhaust system I was looking at adding this summer. Jack Schmitt's people were friendly and knowledgeable. I don't blame them for the cost, but GM should look at doing something. Maybe not a recall, but should pay for at least the part when it goes bad. The lock cost $520.36 and the labor cost was $498.47.
Keep posting if this problem has happend to you. Maybe it will happen to a lawyer out there who will start a class action lawsuit.
#38
2005
#39
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
#40
