Check out these mini amps from Rockford Fosgate!
Former Vendor
I just got some of these amps in today. WOW
They are really small! Check out my cell phone on top of them to give you an idea in size!
These will easily fit below the seats of your car.
PBR300x4
PBR300x1
$149.99 each!
Click here for more info and ordering
The PBR300X4 is a full-range 4-channel amplifier designed for stereo front/rear systems that requires little space.
The BRT (Boosted Rail Technology) is an ultra efficient design that generates 300 Watts of power!
The BRT also has a variable hi-level DC offset turn-on circuit for easy installation into any OEM system.
Details:
The PBR300X1 is a mono amplifier designed for a subwoofer system that requires little space.
The BRT (Boosted Rail Technology) is an ultra efficient design that doesn't even use a switching power supply to generate its 300 Watts of power!
Product Features:
PBR300x4
PBR300x1
$149.99 each!
Details:
- 4-channel car amplifier
- 75 watts RMS x 4 at 4 ohms
- non-bridgeable, 4-ohm stable per channel
- CEA-2006 compliant
- Boosted Rail amp technology
- Dynamic Thermal Management cooling system
- selectable high- and low-pass filters (80 Hz, 12 dB/octave)
- differential-balanced inputs eliminate noise from your vehicle's electrical system
- preamp and speaker-level inputs
- 10-gauge power and ground leads and a 30-amp fuse recommended — wiring and hardware not included with amplifier
- no onboard fuses — when installing multiple amps in a system, an additional 30-amp in-line fuse between the distribution block and the amplifier is recommended
- dimensions: 6-15/16"W x 1-9/16"H x 4-5/16"D
Product Features:
- Punch Series BR Mono Block Car Amplifier
- RMS Power Rating:
- 4 ohms: 75 watts x 1 chan.
- 2 ohms: 150 watts x 1 chan.
- 1 ohm: 300 watts x 1 chan.
- Max Power: 924 watts x 1 chan.
- Ultra compact chassis
- Remote bass level input (remote level control sold separately)
- LED power and protect indicators
- Mono channel operation
- Optional PEQ provides 0dB to +18dB @ 45Hz
- High level speaker input connection
- Low level RCA input connection
- NOMAD protection circuitry
- Convection cooling design
- Extruded aluminum heat sink
- Input sensitivity:
- Low level: 150mV-4V
- High level: 400mV-11V
- Variable DC offset sensitivity
- Built-in 12dB/octave Butterworth crossover
- Crossover frequency: 35-250 Hz
- Frequency response: 20-250 Hz
- Damping factor: >200
- CEA-2006 compliant amplifier
- Dimensions: 6-3/4"L x 4-1/4"W x 1-1/2"H
- 10 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Former Vendor
Former Vendor
price is double for PAcker fans
Anything is better than the PDX amps.
They are not a favorite of mine
With that said
if your wanting quality
call me on pricing for ARC and KEnwood
these are really nice amps
Going to be more than the RF amps but nicer for sound quality.
These RF amps are nice entry level mini amp
I just bought the same car mentioned above, with Bose audio and Nav headunit. I would LOVE to have a complete PLUG & PLAY kit to replace the crap Bose amp and all OEM speakers. I really have no interest in replacing the headunit or adding a subwoofer at this time...
SO -
- Will this Rockford amp (or an Arc, etc.) fit in the OEM location that the Bose amp currently occupies (in the passenger footwell fuse block area) ?
- Can it comfortably drive aftermarket 6.5 & 3.5 component speakers installed in the doors (acting together as channels 1 & 2 for full-range)? They would replace the stock 3.5 door speakers and those stupid Bose bass puffers with built-in amps.
- Could it ALSO drive aftermarket rear 5.25's for mid-bass/rear fill, setup as the 3rd & 4th channels?
- Would this provide a legitimate UPGRADE in sound quality over the stock Bose system, or is it just not enough and a waste of money?
- Could DDMods create such a shippable package, designed for easy installation by the car's owner? The kit would need to include:
- amp
- all speakers (well-matched to this amp)
- installation brackets
- door plates
- all required wiring (pre-cut to a reasonable length so I don't have to buy a 100ft spool of the stuff...)
- etc.
THANKS FOR THE INFO !!
Former Vendor
- - Could we please extend that question?? - -
SO -
YES
the RF amp easily will as well as the KS series mini amps from ARC
You will want 6.5 inch components for doors with adapter plates. The RF will power the speakers. For Sound Quality I would go with the ARC if in the budget. Nothing wrong with the RF but the ARC is known for great sound quality with many C6 customers and members
yes easily
to be honest
chengin speakers liek this will help. To maximize best sound quality a new head unit is always best. With that said you would be still very happy in upgrading amps and speakers to the stock head unit vs factory
- Could DDMods create such a shippable package, designed for easy installation by the car's owner? The kit would need to include:We do this daily
For best way to do this we simply just ask for a phone call. This we we can disuss all the options from budget to what your goals are for future changes as well.
I have kits from 400.00 and up depending on what amps we use and what speakers. A package is available for any and all budgets
SO -
YES
yes easily
to be honest
- amp
- door plates
- etc.
Former Vendor
