Paddle Shift Slack
Paddle Shift Slack
I have a 2006 Convertible with 6 speed paddle shift. When driving 10 to 15 mph and letting up on the gas for a second and then slighlty hitting the gas again it seems to take a second to catch as if there is slack in the transmission or differential. I took it to a dealer and the technician said that was normal for a 6 speed paddle shift transmission. Anybody ever hear of that?
Thanks..
Thanks..
Just one downside to driving an automatic transmission; it has a mind of it's own. Of course their is a reason GM programed it this way, but any tuner knows more than those degreed and experienced GM engineers that conduct tens of thousand of hours of testing and analysis; just ask any shade-tree mechanic on this Forum.
An A6 tune by Chuck Mosello of Corvettes of Westchester (Chuck/CoW) absolutely will not damage your transmission in any way. Chuck will remove the most objectionable elements of "torque management" that hobbles an A6, including retarding ignition timing to zero degrees one tenth of a second before, during, and for a tenth of a second after every shift. He also changes an internal default, enabling the transmission to start off in first gear rather than second. He gave my Red (a very early '07) his custom version of the 2008+ A6 software which added speed matching engine revving before downshifts. I'm sure the detailed list of all of his customizations would be as long as my arm. The end result is a total transformation of the stock A6 from a slushbox to a crisp shifting, fun, and emminently driveable transmission. Well worth every dime.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Thank you very much!
To date, nobody of THOUSANDS of my A6 tunes has had trans trouble yet....
You're in good hands!
Give me a buzz.
Chuck CoW
You are coming up to an intersection where you have a green light. You think it might be ready to turn yellow so you let up on the gas for safety. As you coast thru the intersection you look to your left and see a Mack Truck that is not going to stop. You step on the gas quickly to get out of the way. Unfortunately the transmission is taking it's sweet time deciding which gear it wants to be in resulting in a hesitation before the car moves. BAMM! Your t-boned in the drivers door.
Guess what? You are DEAD, or in so much pain you wish you were. Thanks a lot GM, saved a warranty claim on this car though huh.
This type of programming in a performance car is inexcusable. I would rather sign a warranty waiver on the transmission than drive an A6 operating like that. Shame on you GM.
Former Vendor
Warranty Waiver?!? GOOD IDEA!
The OP is talking about a coast down hesitation in a normal street situation. Did you notice the speeds he was talking about? GM programed the protection in to lower warranty claims which I can understand in abuse situations. This programming in low speed coast down situations can get you KILLED.
Guess what? You are DEAD, or in so much pain you wish you were. Thanks a lot GM, saved a warranty claim on this car thought huh.
Get my tune and I can almost promise you that you'll never get hit by a truck!
Chuck CoW
Received 2,060 Likes
St. Jude Donor '13
Thanks..
Thanks..
We have a 2005 and 2011 Toyota Camry V6 that are at least as bad in that respect as our 2006 A6 Corvette.
Can the 06 A6 be tuned for rev matching also? If so does it work with the paddles or just in auto mode.
As soon as my GMPP poops out I will send in my Trans module or if Chuck Cow is in the Bay area of California I will go there.
Come on now Toyota's? The brand that won't quit accelerating when you take your foot off the gas and step on the brake. Not a very good choice for comparison. I've had almost 20 GM automatic vehicles over the years and never had one with a transmission related hesitation like this. In a tight spot the stock A6 can literally scare you.
St. Jude Donor '13
Have you been able to test drive & compare your car with another similar 2007, or a 2008/later with the LS3? Wondering if there is any difference year-to-year, or car-to-car.
We put 44k miles on the 2006, and now 24k miles on the 2009. The lag can be slightly annoying, but it's been there somewhat in every automatic car I've owned. In all those C6 miles I've never experienced anything in the tranny that scared me.
I think Chuck should do a nationwide summer Tour like the rock shows.
I'm sure he could coordinate with local tuners/performance shops for a place to park the 'Tour Vehicle/shop-on-wheels'.
Groupies optional.
Groupies optional.
I don't see what Toyota's sticking throttle linkage has to do with anyone's transmission lag.
Yes I have driven 7's, 8's and 10's. Good improvement from 7 to 10 on the paddle shift time. Not very much on the coast down hesitation. A tranny tune helps both problems and I feel it is a must.
You won't really know what I mean by scared until you try to goose it to avoid a possible accident then the hesitation seems to last for ever!
It does not do it every time and some are worse that others. If I went out now and tried to demo it I might or might not be able to duplicate it in a short period of time. Obviously several parameters must be met for the lag to occur. The coast down problem has occurred multiple times but once I pulled out to pass at around 50, goosed it as I normally would and nothing happened. I waited and was about to let up when it down shifted to far and if not for traction control might have fish tailed. It literally feels like it doesn't know which gear to pick for a second and then when it does pick its the wrong one!
I'm guessing you have not experienced the lag or hesitation some of us are talking about. Trust me it is not something that you would describe as being common to other auto cars you have owned. If it was you would have given up on autos a long time ago. I actually wish I had a good old turbo 400 in the vette instead of the A6. The only thing I would miss is the overdrive gearing.
