Tires - Kumho
Old 12-29-2010, 10:05 PM
KCC6Vert
KCC6Vert's Avatar
St. Jude Donor '10-'11
Originally Posted by STLBLUES
If you want a quiet tire in the same price range try the Hankook Ventus. I will definately get another set of the v12s when mine wear out.
We're all biased, but I replaced Firestone run flats with the Hankook Ventus and was amazed at the ride improvement and have been thrilled at how much quieter they are. I would repeat my decision without hesitation.
Old 12-29-2010, 10:13 PM
diyguy
diyguy's Avatar
...couldn''t give a rat's arzzz what 'tests' bear out. The OEM GY's are crap tires, noisy, and almost scary on cool wet concrete. I've got about 35-40 % remaining on OEM's and over the last couple of days it's been cool, and rainy, foggy, drizzle. It borders dangerous IMO what lousy traction and how so very easy they are to break loose with just the slightest blip of the throttle. Thank God for tracton control and active handling.... I now take corners a lot more seriously!
Can't wait for a dry day, so I can lock the front and smoke those to the belts and get some real tires. The Kumho's are in contention. Also the Toyo T1R's are at the top of the list too.
2 C5's and a C6, and my first set of OEM's on the C6 acquired about 6 weeks ago. If there were a worse tire, I'd like to know what it is... Tire Rack rates them at the very bottom....#29 I think, last time I looked.
Old 12-29-2010, 10:29 PM
greengo
greengo's Avatar
Firestone Wide Ovals are awesome and a steal at their price !
Blow the Badyears away and are quiet too !
Old 12-29-2010, 11:58 PM
NARIMAN
NARIMAN's Avatar
i drove on kumho esta xs on few auto x events, and it is the best tire i ever had, just good for summer
i am selling them, because i have nitto invo for every day,
Old 12-30-2010, 12:31 AM
lkelliott
lkelliott's Avatar
I used Kumho Ecsta SPT's on my C5 and C6. They are great tires, I did not find them noisy at all. They will give you very decent mileage from the SPT tires.
I tried the Kumho Ecsta XS tires and they are a very grippy tire. They are a softer compound than the SPT's. I got 18k miles on them with my C6. I like the XS's for the great cornering lateral grip they give.
I also autocross and the Kumho Ecsta V710 tires are simply the best autocross/road race tires around!
Kent
Old 12-30-2010, 06:00 AM
Supercrewbear
Supercrewbear's Avatar
Originally Posted by Brian2010
The grand sport rears will cut into your selections grately try nitto invos.
On the Nitto tire web page they do not have the 325/30-19 size for the rear...
Old 12-30-2010, 07:51 AM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
I too have Kumho Ecsta on my '07 and they work surprisingly well for regular driving. I've got 67K miles on them now and the rears will be due in the next couple of months so I'm starting to shop. I'm no longer cranking out the miles as a DD since I retired so they'll last. I have noticed that the Kumhos easily break lose as the temps fell for winter out here but that should be true for most all tires. Before moving here, testing them in the S. Calif. mountains, they held grip very well and certainly quieter than the GY's.
Old 12-30-2010, 08:47 AM
Brian2010
Brian2010's Avatar
I have some comming in today ups from my friend who is a dealer. They definetly have them I been researching for 3 week I will get you the link and post or pm.
Old 12-30-2010, 09:05 AM
Brian2010
Brian2010's Avatar
Here you go.
http://www.nittotire.com/index.html
Old 12-30-2010, 09:52 AM
Dave_C6
Dave_C6's Avatar
I've got 5,000 miles on my Kumho Ecsta SPT's. Replaced the stock GYs. Compared to the GYs the SPTs are MUCH quieter. The comment about the stock GY sidewalls being stiffer is true, and you will feel some flex going into corners with the SPTs. However IMO the SPTs are far better all-around tires for daily driving. They grip, and under HARD throttle slide predictibly (I used to race and know how to push a tire to its limits).
The secret to getting the best performance out of the Kumho Ecsta SPT's is to run them at 31.5 lbs (at least here in Scottsdale AZ... tire performance will vary according to temp, elevation, and many other factors). At 31.5 lbs the tires are extremely stable at all speeds but give a remarkably nimble feel to the steering... super quick but never twitchy. So responsive is the handling that I can tell when the pressure is off by 1 lb.
When I was racing I learned that high performance tires were a waste of money unless you were using them to the maximum, and I learned to run cheap tires to their very edge - enough to beat guys running the high dollar shoes. The SPTs are plenty good for the street if you know what you're doing. I run them hard and won't mind buying a fresh set when I reach 40-50 wear so take my comments with a grain of salt.
Old 12-30-2010, 10:16 AM
DarthStimpy
DarthStimpy's Avatar
I'm a big fan of Kumho, I think they turn out some fantastic products for a great price.
I run the SPTs on the street, I've gone through two sets. the first one lasted me just over 21k miles. They wear very well, but dont drive like they're made of stone.
I used the XS as a street class autocross tire. They are very good in the dry and warm, but loose a lot of grip in the wet. And have very little grip below 50 degs F. I would say do not run these in the a cold rain.
I now run the V710s for autocross. these tires are great. they have a grip that is slightly better then a Hoosier R6.Hand they last forever, they grip right up until the cords, where as the R6s get heat cycled out long before the rubber runs out.
Old 12-30-2010, 10:52 AM
Grumpy
MONARTOR
Grumpy's Avatar
Location: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-10-'11-12-'13-'14-'15-'16-17-'18-'19'-20-'21-'22-'23-'24
been thru the OEM runflats, Kuhmo SPT's, Hankook Ventu v12's and am now on Conti Extremes... Like the Conti's so far. THe Hankook's lasted pretty well, the Kuhmos gave my installer hell trying to balance them.
got em all from www.tirerack.com
Old 12-30-2010, 11:10 AM
  #33
goatts
goatts's Avatar
Are your tires past the wear bars? Are they the original OEM tires? Also, what tires have you tried on your vette other than OEM.
Old 12-30-2010, 02:58 PM
  #34
SRQStingray
SRQStingray's Avatar
Originally Posted by goatts
Sorry the facts don't support "nosie". See the link on my post #14, read and learn.
I don't think any tires are nosie, but some are noisy
Old 12-30-2010, 04:30 PM
  #35
goatts
goatts's Avatar
...couldn''t give a rat's arzzz what 'tests' bear out. The OEM GY's are crap tires, noisy, and almost scary on cool .
Darn right! Wouldn't want to inject actual facts into this discussion (especially when they don't agree with your opinion).
Quick Reply: Tires - Kumho
