New Adviise
New Adviise
Ooops...Subject should read Need Advise. Fingers wasn't reacting to brain
I am ready to purchase a C6. Since this site is such an excellent source of information, I was wondering if you would answer a few questions...
1) Any differences between 05-08?
2) Any recalls during 05-08?
3) Does a manual really makes that much of a difference?
4) New vs used?
5) Is the navigation system a good option?
Thanks in advance and Happy Holidays to All.
4) New vs used?
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
Since you're on here since '06, I'll take these as real questions, but you have to do some searching in the C6 Gen section to answer more of your questions. One answer: yes, there is a fairly large difference betw. '05 and '08, and then '10 Grand Sports models.
A few on specific items, and more TSBs.
Only if it makes a difference to you.
4) New vs used?
What's your wallet?
Not to me, but a lot like it. It means a single disc CD player vs. a 6-disc, if that's worth anything to you.
Use "search" in red band at top, limit to C6 Gen, go advanced search and put in key words in the left hand top search box. You'll have to work for rather than have one post and everyone answering your questions.
Good luck.
4) New vs used?
What's your wallet?
Good luck.
Newer is almost always better.......especially where the '08+ is concerned. Lots of upgrades/changes to the '08's.....
LS3=430HP or 436 with the NPP dual mode exhaust,
manual trans changed from T56 to TR6060,
A6 trans got upgraded software with rev match on downshift,
availability of 4LT all leather interior (if you're into that),
different wheel styles
and some other little stuff.
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,470 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Actually it's advice not advise you're looking for.
1. LS2 to LS3 is the main. 4 speed auto in 05, 6 speed auto for the others. Option packages changed over the years.
2. Several
3. Not to me but for some it matters.
4. 05-08 would all be used by now. Low miles and great deals are plentiful. If you want a full warranty and your choice of options, order new.
5. I like it and I use it.
2. Several
4) New vs used?
4) New vs used?
2. '05 had a few problems; Crank pulley, weak differential, etc. '08 had a differential fluid change.
3. Not to me, I'm happier with the A6 in the '08. It's just as quick, less problems (no skip shift, no clutch fluid changes, no replacement clutch worries, no short shifter needed, hassle free driving in traffic and on steep hill starts).
4. Used is ALWAYS cheaper but I bought both new and suffered the depreciation of $7-8,000 the second I drove it off the Dealers lot. There's something about a Virgin; Never "rode hard and put up wet"?
5. Ended up with Nav. in both, probably the stupidest $1800 I ever spent.
Advice? Buy the newest lowest mileage '08 or newer with the color and options you want that you can easily afford.
