Ever been locked INSIDE your Vette?
Old 12-02-2010, 09:04 PM
PrimeTime327
PrimeTime327's Avatar
Default Ever been locked INSIDE your Vette?
This is crazy but I picked my '08 from the dealer after having TSB work done on the two seals in the tranny. When I walked up to the car the driver's window was down and the FOB was on the console.
"No FOB" was indicated and it wouldn't start until I exited the car and re-entered. I drove to dinner and when I came back to it the lights came on bright but it wouldn't do anything "EXCEPT" lock me inside the car. The door button, door lock, windows and OnStar would not work? OnStar said this was a first!
I was locked in there for almost ten minutes, then the alarm activated and it started???
Headed back to the dealer in the morning, any idea what happened?
Thanks!
Old 12-02-2010, 09:07 PM
not08crmanymore
not08crmanymore's Avatar
UM,You do know about the emergency release door lever on the floor by your left leg and right leg on the passenger side,right?
Old 12-02-2010, 09:08 PM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
It has been said that funny things can happen when the battery itself gets low on juice. Sounds like someone left something on for awhile and the battery is run down. Have them check the battery. Has the car ever not started before?
Old 12-02-2010, 09:10 PM
RicK T
RicK T's Avatar
You know about the emergency door release levers next to the seats....yes?
Likely just a run down battery. Charge it......or replace it if appropriate.
Old 12-02-2010, 09:21 PM
PrimeTime327
I was on my phone trying to diagnose the problem and absolutely forgot about the manual release! I have a two month old battery with a full charge, my lights were the normal brightness, unlike me!.lol
Just went back to it and there is a very faint buzzing sound when I push the Start,Acc,Stop switch and the brake pedal is very stiff?
Old 12-02-2010, 09:24 PM
TBonez
2005 Beast
Support Corvetteforum!
TBonez's Avatar
Old 12-02-2010, 09:30 PM
EVRose
EVRose's Avatar
I've haven't had to take mine to a dealer for service yet but this is a perfect example of why I dread ever having to. They fix one thing (hopefully) and screw up something totally unrelated to the problem it was there for in the first place.
Old 12-02-2010, 10:10 PM
PrimeTime327
I agree with you. I went from no scuff marks to three major marks on my entry panel that won't come out, plus one nasty grease spot on my new Lloyds Mats?
Update: Reset the FOB and no problem now, thanks guys!
Gary
Old 12-02-2010, 10:26 PM
vant
vant's Avatar
God help the poor bastard that forgets about the emergency door pull in an actual emergency.
Old 12-02-2010, 10:36 PM
MARSC6
MARSC6's Avatar
A few years back I was trapped. The negative terminal on the battery came loose and the drivers side sill protector was a bit out of place blocking the emergency release lever. I had to crawl across the console and exit through the passenger door which is very difficult in these cars.
Old 12-02-2010, 10:47 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
Old 12-02-2010, 11:05 PM
vettedoogie
vettedoogie's Avatar
No and I don't expect to be unless I'm no longer breathing.
Old 12-02-2010, 11:08 PM
su8pack1
su8pack1's Avatar
No, but the wife did right after we got it.
Old 12-02-2010, 11:18 PM
K9KUZ
K9KUZ's Avatar
I have had several situations like this. Both while I was in the car and while trying to get in. Probably happens once every month. Not a battery problem, just some gremlins. More annoying is when I have a armfull of groceries and the trunk will not open. This happens about 3x per year.
Old 12-02-2010, 11:23 PM
TBD
TBD's Avatar
Unbelievable. Everyone with a brain knows you kick out the window(s) when that happens.
Peace, out.
Old 12-03-2010, 12:03 AM
spearce
spearce's Avatar
I got locked in a Corvette at my local dealership. While I was looking I got into the show room Corvette and closed the door. I went to get out and the door wouldn't open. The salesmen had no idea about the lever. He had to get the sales manager who knew about the lever. The manager said " If You're stuck, you bought it".
Old 12-03-2010, 07:33 AM
lastcowboy
lastcowboy's Avatar
left someone setting in the car and took off......came back later she
was still setting there screaming she could'nt get out,,she did'nt know about the release and i forgot about it auto locking....
To Ever been locked INSIDE your Vette?
Old 12-03-2010, 09:37 AM
davanz
davanz's Avatar
If it was a real emergency situation, and the emergency levers were not functional, (they should be as they are mechanical, not electrical), there is the removalble roof panel to consider, if so equipped.
Old 12-03-2010, 09:40 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Another car hits the right front and destroys the battery. Car is on fire. And the driver is thinking about phoning for help but totally forgets for 10 minutes that there are emergency releases on the floor.
Low battery seems to be the most likely cause of all your problems except the memory issue.
BTW, how do you "Reset the FOB"? Sounds like the dealer didn't have a clue either.
Old 12-03-2010, 09:45 AM
chris12.8
chris12.8's Avatar
http://www.youtube.com/watch?v=R0nRvqfiqZI
Quick Reply: Ever been locked INSIDE your Vette?
