Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-28-2010, 02:34 PM   #1
torchredfrc
CF Senior Member
torchredfrc's Avatar
Send a message via ICQ to torchredfrc Send a message via AIM to torchredfrc
Default P0833 Clutch pedal position switch (cruise problem)
The service bulletin relevant to this code mentions the following switch:
clutch pedal cruise control release switch
Can anyone tell me the part # for this or where it is located? I replaced the lower switch trying to fix this issue and get my cruise control back online but now need to find this guy and replace it.
Thanks!
torchredfrc is offline   Reply With Quote
Old 11-29-2010, 11:40 AM   #2
torchredfrc
CF Senior Member
Wanted to add this to see if it gave anymore info for anyone to go off of:
#05-08-68-001B: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch) - (May 29, 2008)
Subject: Malfunction Indicator Lamp (MIL), Diagnostic Trouble Code (DTC) P0833, Cruise Control Inoperative (Adjust Clutch Release Switch)
Models: 2005-2007 Chevrolet Corvette
with 6-Speed Manual Transmission
Condition
Some customers may comment on a malfunction indicator lamp. Some customers may also comment that the cruise control is inoperative.
A scan tool may reveal a DTC P0833. Cruise Disengaged History Reason will display "Lost Forward Gear" on Tech 2.
Cause
The clutch release switch may be misadjusted.
Diagnostic Information
There are two clutch switches
• The lower switch, the clutch start switch provides feedback to the PCM that the clutch pedal has been depressed to enable starting. This switch DOES NOT relate to the P0883 code.
• The upper switch, the clutch pedal position switch also referred to in SI as the clutch pedal cruise control release switch, provides the PCM feedback as to the position of the clutch pedal.
• Refer to Manual Transmission Component Views, Figure 2: 01 Y-Car: Comp Loc Views (Under LH Side of the Dash) in SI for switch locations.
Important: Multiple clutch presses during a single stop may provide inaccurate feedback to the PCM and the technician may misdiagnose the need to replace the PCM. The Tech 2 may not pick up the multiple presses which would appear that the PCM is not picking up the signal. The PCM should not be replaced if the Tech 2 does not pick up multiple clutch cycles during testing.
Old 11-29-2010, 02:16 PM   #3
C6ToGo
CF Senior Member
C6ToGo's Avatar
Isn't it down at your pedal??
C6ToGo is online now   Reply With Quote
Old 11-29-2010, 02:22 PM   #4
B y r o n
CF Senior Member
Support Corvetteforum!
B y r o n's Avatar
According to what you posted it sounds like you might just need to adjust it, like a brake light switch to get things working again.
B y r o n is online now   Reply With Quote
Old 11-29-2010, 07:17 PM   #5
torchredfrc
CF Senior Member
The "lower" switch is the one I replaced and it is down by the pedal. I was unable to locate a drawing that showed me where the upper switch was so I could perform said adjustment. I might have missed it but I couldn't find it none the less.
Old 11-29-2010, 07:18 PM   #6
torchredfrc
CF Senior Member
Quote:
That's kind of what I thought as well. Once I know where the thing is, this should make a lot more sense to me. The light I had when I was down there wasn't the best and I didn't see another switch in the clutch pedal replacement procedure... and that's why I'm asking here.
Old 11-29-2010, 07:27 PM   #7
dpigguy
CF Senior Member
dpigguy's Avatar
try sending Talon90 a PM. he usually can provide the illustration and technical data on most items like this.
dpigguy is offline   Reply With Quote
Old 11-29-2010, 09:26 PM   #8
torchredfrc
CF Senior Member
Thanks dpigguy. I just sent him a PM and a link to this thread.
Old 12-01-2010, 03:21 PM   #9
talon90
Moderator
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
talon90's Avatar
Quote:
Sorry for the delay. Got your PM and just replied with document links attached.
Paul
talon90 is offline   Reply With Quote
Old 12-30-2010, 02:54 PM   #10
torchredfrc
CF Senior Member
I wanted to post an update. I checked all the switches related to the clutch pedal and notice the pedal wasn't traveling all the way to meet with the upper switch. Turns out the fluid was a bit low. Added fluid, reset the DIC and everything is working as intended!
Thanks for everyone's replies and help.
Old 05-14-2011, 11:28 AM   #11
jsizzle2k6
Junior Member
jsizzle2k6 jsizzle2k6
Im having the exact same problem. Anyway one of you can send me the links and documents as well
jsizzle2k6 is offline   Reply With Quote
Old 05-14-2011, 01:06 PM   #12
BEZ06
Formerly beezeye
BEZ06's Avatar
Quote:
I don't have the "links and documents" you're interested in, but take a look at this picture, and click on the link below the picture to see a list of all the part #'s for all the items in the picture. #35 is the "cruise control release switch" and # 8 is the "clutch pedal position switch":
Click the image to open in full size.
Here's the link to that picture with a list of part #'s (double check them - this isn't an official GM site):
http://www.compnine.com/index.php?u=...00&grouptype=B
Good luck!
Bob
__________________
BEZ06 is online now   Reply With Quote
Old 09-13-2012, 10:50 AM   #13
greatgonzer
CF Senior Member
I just got this error code today "P08333 Clutch pedal switch 2 circuit" also. Can one of you send me the diagram that talon sent out? I'd be greatly appreciative!
greatgonzer is offline   Reply With Quote
Old 09-13-2012, 10:57 AM   #14
Wayne O
CF Senior Member
Wayne O's Avatar
You could always call Gene at gmpartshouse.com and have them track it down for you. Good luck!
__________________
2005 Corvette C6 Coupe
Magnetic Red Metallic II/Cashmere, MN6, 1SB, F55
Lingenfelter 403 Conversion, LG Pro Headers (coated), Corsa Sport Exhaust, Lingenfelter CAI, Accusump, LGM Coil-Over Suspension & Bump-Steer Kit, T1 Sway Bars, Pfadt Control Arm Bushing Kit, Elite Eng. Tunnel Plate & Oil Catch-Can, SKF Racing Hubs/Bearings, AP Racing Brakes, DRM Brake Ducts, Custom Roll Bar, Sparco Seats, Wide-Booty, CCW C10 Wheels,
Setup: LG Motorsports
Thanks to: 21st Century Muscle Cars
Wayne O is offline   Reply With Quote
Old 11-09-2013, 08:06 PM   #15
Bagman0
Junior Member
I got the error code today for clutch b switch. I ordered one (only 6.00) but am having a hard time finding anything on the location of the darn thing to change it out.
Any help would be great.
Bagman0 is offline   Reply With Quote
Reload this Page P0833 Clutch pedal position switch (cruise problem)
Tags
2007, adjust, brake, c3, c5, c6, clutch, control, corvette, cruise, light, p0833, pedal, pedals, position, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
