Dr Color Chip
Dr Color Chip
Any one ever use them?
I watched the videos on the website, he does a dark blue BMW and it appears that it blends the chips nicely.
He doesn't list Victory Red on his website for 2008 Corvettes - just Red.
Since the car will be tucked away for most of the winter, I figured now would be a good time to make the road rash disappear.
And I did a Search for them - nothing came up - and searched the Paint & Body forum as well.
Thanks,
Ken
Thanks,
Ken
They've been discussed on here a few times. I have their kit for my arctic white 2008 and I'm happy with the results. It won't make everything completely disappear, but it is much better than using regular touch paint. The process is shown pretty well on their website. I don't know about the color match for your Victory Red, but I imagine you could email them and confirm that they have the match.
Thanks,
Ken
Thanks,
Ken
Found it - it does match - the RPO Code for the paint is 74u - paint code is U9260 - they list it on their website as 74/wa9260 - they just call it red versus Victory Red.
Cool - thanks guys - 69 bucks later. It'll give me time to do it over the course of this winter here in BC.
I have been told that this stuff works well for chips but not so well for scratches. Anyone have experience? Somehow I got a couple of very fine scratches on my black coupe. No one notices, but I would like to get rid of them without spending a fortune.
I have been using their paints for years on many diff cars, it works great for chips and such, never tried it on a scratch, the trick is the reducer used after the paint, just fill the chip with the paint, try to overfill it a little and go past the edge of the chip, once the paint dries put the pink reducer on a microfiber cloth and gently start to clean off the paint, will not hurt the surrounding factory paint, just will gently remove the excess paint from the chip. if you do not like the repair just continue to wipe all the touch up paint off and start again.
I just use a little clear, touch up the scratch, and then knock it down with some 2000 grit wet paper, then buff and polish. the clear scratches will blend right in. My drivers mirror had a good size scratch in it from the previous owner, I touched up with some base black, and then cleared it. You would be hard pressed to find the repair.
I used it on the wifes BMW about six months ago. Works well, you have to search hard to find where it fills in small chips. Ordered some for the CRM vert but hope I'll never have to use it.
I've used it on my Magnetic Red 05 for minor scratches. It worked OK, better than regular touch up, but nothing like the ad shows. However, I've had better luck with a fine rubbing compound and multiple polishings once I got the scratch taken care of with the rubbing compound.
SUBVETTE
