Automatic vs Manual Trans
Old 10-10-2010, 04:57 PM
clarkakirby
clarkakirby's Avatar
Default Automatic vs Manual Trans
I have a 2010 Grand Sport with the A6/paddle shifters. I read somewhere that the manual cars have a transaxle but the automatic trans cars do not. That is, the automatic trans is bolted to the rear of the engine in Grand Sports. Anyone know?
Old 10-10-2010, 05:19 PM
kwickag
kwickag's Avatar
The transmission is in the rear on both.
Old 10-10-2010, 05:32 PM
last901
Support Corvetteforum!
last901's Avatar
Seems to me I read that somewhere too.
Crawl under the car and look
Old 10-10-2010, 06:13 PM
tim414
tim414's Avatar
St. Jude Donor '12
Hey man, I believe ALL C6's, whether base, GS, Z06 or ZR1 are REAR mounted trannies.
Old 10-10-2010, 06:41 PM
TCW
TCW's Avatar
St. Jude Donor '06-13,'16-'17, '19
Wrong! The slushbox is mounted to the differential.
Tom
Old 10-10-2010, 07:20 PM
last901
last901's Avatar
Hey man? Gee, that sort of salutation really gives you away as an authority...
Frankly, I don't care if the damn transmission is in the glove compartment. I'm just agreeing with the OP that I seem to recall reading that the A6 was mounted behind the engine. Admittedly I may have misread something having to do with the manual transmission GS cars being fitted with the dry sump engine and the automatics not.
Sorry if I insulted your intelligence... man.
You may very well be right...man.
Peace...man
Old 10-10-2010, 07:28 PM
rovers2000
rovers2000's Avatar
you are correct all trannies are in the rear.
Old 10-10-2010, 08:28 PM
ninjavette
ninjavette's Avatar
Peace...man
I think you're being a little over sensitive. I don't see where his comment can be interpreted as him talking down to anyone.....man
Old 10-10-2010, 08:29 PM
last901
last901's Avatar
Yes, you're probably right. It's the bad thing about Email and forum responses.
No offense intended,
Old 10-10-2010, 09:02 PM
ninjavette
ninjavette's Avatar
Unfortunately this form of communication eliminates that very important aspect of how something is said.
Anyway, the drive train layout of all C6s is the same. Engine in front, trans and diff in rear. I'm not sure where this misinformation is coming from but it's also not the first I've heard/read it either. It seems someone out there is trying to confuse us.
Old 10-10-2010, 09:28 PM
Vette5.5
Vette5.5's Avatar
All C5/C6 transmissions are mounted in the rear, whether automatic or manual. None can truely be called a transaxle, as even the manuals gear case is isolated from the diffential's and does not share the same lubricating oil.
Old 10-10-2010, 09:32 PM
grump
grump's Avatar
Default Thats right
Old 10-10-2010, 10:10 PM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Moving the trans to the rear is one of the key things that helps balance the car out( C5 and C6). Both Autos and Manuals are in the rear.
Old 10-10-2010, 10:21 PM
jschindler
jschindler's Avatar
Peace...man
Heeeey sweet cheeks, I just want you to know that all C6 transmissions are in the rear of the car------ewwww, that is so fine..............
Is that how you wanted to hear it?
Old 10-11-2010, 12:43 AM
Marc V.
Marc V.'s Avatar
That is 100% correct.
A true "transaxle" has the final drive gears in the same case as the transmission gears, as in a front wheel drive car.
In a C5 and C6, the final drive is a seperate unit.
Old 10-11-2010, 01:05 AM
Cratchet
Cratchet's Avatar
While we're on the subject, is the linkage from the shifter via cable?
Or some other method?
Thanks!
Mike
Old 10-11-2010, 01:17 AM
haljensen
haljensen's Avatar
Thanks!
Mike
Shifting on the Manual C6 is by a single rod from the shift lever to the transmission. That single rod gives 3 positions in and out and an additional 4 positions by rotating.
To Automatic vs Manual Trans
Old 10-11-2010, 01:53 AM
See5see6
See5see6's Avatar
In Corvette Magazine, Issue #60, October 2010, an article beginning on page 42 wrongly states that automatic transmission equipped Grand Sports have "the gearbox mounted directly behind the engine instead of at the rear axle as it in on a manual tranmission-equipped car"....................
In their Issue #61, December 2010, on page 12 they straighten out their error.
So perhaps that is what got some confusion started. Even a classy (my opinion) mag. like Corvette Magazine can and will make errors once in awhile.
Old 10-11-2010, 02:10 AM
Marc V.
Marc V.'s Avatar
Isn't that what they pay an editor for?
Old 10-11-2010, 02:19 AM
See5see6
See5see6's Avatar
Perhaps so. Maybe the editor was having a bad day. Maybe he just goofed. The editor did apologize. My post was more in support of the original post by clarkakirby than it was to defend Corvette Magazine.
Quick Reply: Automatic vs Manual Trans
